Valve seal or piston rings?
Old Jun 14, 2020 | 07:40 AM
Dr.Hess's Avatar
Dr.Hess
I would not reuse the gaskets. It is a lot of work to take all that off, and risking a leak just isn't worth it. Now, if you HAVE to, the rubber type gaskets can be reused. But you don't know how long those things have been on there, so just count on a gasket set.
If the plugs aren't covered in oil, I would not worry about a little smoke. Or is it fogging? That is, a lot of smoke? How long does a quart of oil last? Using a quart in 1000 miles (2.2KM) is pretty normal.
Old Jun 14, 2020 | 07:50 AM
TwiZted Biker's Avatar
TwiZted Biker
Always replace any motor gaskets, only time I ever reuse one is the primary cover. You don't want to do things twice to try and save a buck or two.
Old Jun 14, 2020 | 08:31 AM
Elecglide's Avatar
Elecglide
It's not fogging, but it is noticeable. I will do the compression test, and I will come back with the results.
Old Jun 18, 2020 | 12:22 PM
Elecglide's Avatar
Elecglide
Ok,
I am back. Did the compression test. Here the pics:
What do you guys think? There is some difference, but is it so bad? Or is it tolerated?
Old Jun 18, 2020 | 12:28 PM
Dr.Hess's Avatar
Dr.Hess
I don't think that looks too bad. I think the spec for "bad" is 10% difference, in general, and you are under that. If I were you, I'd just run what you have and not worry about it. Eventually, the base gasket(s) will start leaking and you can re-ring it then.
Old Jun 18, 2020 | 12:35 PM
Elecglide's Avatar
Elecglide
Thanx for your fast reply.
When I checked the plugs again, they where black. Is it a sign that it runs to rich?
Old Jun 18, 2020 | 01:15 PM
mike131's Avatar
mike131
if black sooty, yes rich
Old Jun 18, 2020 | 01:21 PM
Elecglide's Avatar
Elecglide
Thanx, Mike
Old Jun 19, 2020 | 02:13 PM
mike131's Avatar
mike131
no problem
Old Jun 19, 2020 | 03:28 PM
eighteight's Avatar
eighteight
[QUOTE=Elecglide;
PS, sorry 4 my bad writing. I am from Belgium.[/QUOTE]
Please don’t apologize, your English is way better than our Belgian !
”Half the world is bilingual, the rest are Americans”
lol
