dying while riding
Old Jun 16, 2020 | 04:13 AM
grbrown's Avatar
grbrown
Talking
Sure they do.. saddle up the old iron horse and mount a Winchester 30/30 to it... Ahhh... Just like the good ol days..
As for the OP. did you do a full flow test to the carb as well as checking the float level?
I'll take my 45/70 thanks! My first Harley, back in 1974:
Old Jun 16, 2020 | 08:40 AM
Beemervet's Avatar
Beemervet
My, such a stud you were! Mrs. Brown in the background too!
Old Jun 16, 2020 | 08:51 AM
Beemervet's Avatar
Beemervet
Old Jun 16, 2020 | 11:13 AM
grbrown's Avatar
grbrown
Red face
That's best described as a 'library picture'! And some time before the real Mrs B came into my life....
Old Jun 16, 2020 | 11:49 AM
bagga's Avatar
bagga
Originally Posted by lunyty1
87 FLH Sport,,,with 96" S&S motor,,,,,runs great but lately it will just die while riding,,i pull over and it starts right back up,,not losing any electric,,no warning light on dash till oil pressure falls ......all lights and stereo stay on just lose motor electric...i checked coil resistance and it's 10800 which is great,the ignition is compu-fire elite 1 ,,i went back to dual fire a couple months ago when i had to change coils and i had a dual
fire on the bench,but coil is testing good and none of the wires are crispy,,please help i'm riding to the beach in 3 weeks,and i'd like to figure this out before i go,,any help much appreciated
could be the 15 amp ignition circuit breaker. I had one on my 85 go bad after it was about 20 years old.
Old Jun 21, 2020 | 09:23 AM
lunyty1's Avatar
lunyty1
Default Update
went for a 200 mile shake down run,,and made it 100 miles,,stator plug melted,,,maybe i was losing the stator all along ???
Old Jun 21, 2020 | 06:59 PM
mike131's Avatar
mike131
could be the stator shorting out killing the bike popping the circuit breaker, or that could be just a bad wore out plug with loose connections, have you checked the stator to see if its charging or shorted to ground?
Old Jun 22, 2020 | 06:33 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Ideally melted wiring at a convention is indeed a poor connection.. still as Mike says test your charging system.. Sticky it's at the top of this forum..
Old Jun 22, 2020 | 09:59 AM
lunyty1's Avatar
lunyty1
It completely melted the pins on the reg,,and the females on the stator,,so i cant get to any good wiring,,,,new one will be here in a couple days,,,this one lasted 9 years,,,,i mean it melted the rubber plug on the stator down in the inner primary ...
Jolly_Roger
18
Jun 17, 2019 06:54 PM
LoneRangerAK
Electrical/Lighting/Alarm
May 30, 2016 07:42 PM
71shovelpolicespecial
Shovelhead
Apr 14, 2013 02:17 PM
lagunatic
Shovelhead
Jan 17, 2013 05:36 PM
troglodyte
Sep 5, 2005 07:46 PM
