dies while idleing
Old Jun 20, 2020 | 05:50 PM
98hotrodfatboy's Avatar
98hotrodfatboy
That would be a good place to start... Known good ignition.... Ultima's are pretty good..
Old Jun 20, 2020 | 06:41 PM
mike131's Avatar
mike131
I've had good luck with Ultima ignitions
Old Jun 22, 2020 | 06:12 PM
BigMike67's Avatar
BigMike67
ok fellas, turns out i'm not to smart or just didn't notice the idle was low, turned the idle up a bit and it was fine..
on another note the spring for the idle screw is not strong enough to keep it from un turning and lowing my idle... do you think a drop of Green Loctite would be ok to put on the threads to keep it from moving?
Old Jun 22, 2020 | 06:16 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'd try blue before I tried green.
Old Jun 22, 2020 | 07:12 PM
mike131's Avatar
mike131
Im glad you found the problem BigMike stretch the spring or add a couple small washers?
Old Jun 22, 2020 | 10:39 PM
BigMike67's Avatar
BigMike67
i tried stretching the spring last summer.. i looked up loctites site and the purple is the one for small bolts and screws, minimum strength. thanks again for the help folks!
Old Jun 23, 2020 | 03:39 AM
grbrown's Avatar
grbrown
Red face
How about buying a new spring? I'm not sure that Loctite in a carb is a good idea!
Old Jun 23, 2020 | 07:42 AM
BigMike67's Avatar
BigMike67
GBrown. i have triend multiple springs last year. the carb is only a year old so it's not warn out.. if i can find small enough washers i will try that first. trust me i'm in no hurry to put Locktite on there but i can't have the bike shutting off or idling too high...
Old Jun 23, 2020 | 09:19 AM
98hotrodfatboy
You sure you don't have a vacuum leak going on somewhere causing an erratic idle at times. I've never seen a spring cause that problem on the idle adjustment. Which carburetor do you have?
Old Jun 23, 2020 | 09:33 AM
GBHH's Avatar
GBHH
How about marking the screw's position at the ideal adj. and see if it is in fact turning
