dies while idleing
Old Jun 23, 2020 | 10:35 AM
mike131's Avatar
mike131
You sure you don't have a vacuum leak going on somewhere causing an erratic idle at times. I've never seen a spring cause that problem on the idle adjustment. Which carburetor do you have?
That definitely could be true!
Old Jun 23, 2020 | 09:41 PM
BigMike67's Avatar
BigMike67
great suggestions...running a Super G.... got home in time to miss the storms tonight so tomorrow i'll be testing the screw itself... changed plugs today and they looked real good...
Old Jun 24, 2020 | 05:04 AM
98hotrodfatboy's Avatar
98hotrodfatboy
You can call S&S and they should be able to get you a new spring.. can't be that much.. part number 67-562. Motor vibrations can cause weird things to happen.. my 96" Evo at higher rpm's would actually vibrate the full petcock closed. 6000-6500 range..
suthpaw22
Dec 8, 2013 12:49 PM
jhnmflr
Mar 24, 2012 03:59 PM
tcs59
Sep 10, 2008 06:33 PM
MANCHU DOG7
Jul 12, 2007 03:48 PM
ggold
Aug 6, 2006 08:53 PM
