Which Hylift Johnson Lifter?
Old Jun 24, 2020 | 06:07 PM
LQQK_OUT's Avatar
LQQK_OUT
Default Which Hylift Johnson Lifter?
I'm looking to pickup a set of Hylift Johnson lifters. They seem much more reasonably priced compared to what S&S Cycle offers.
Which model is recommended for an 80 ci EVO running with a bolt in cam?
B2303 - OEM Stock Leakdown High Endurance Steel Body
B2303S - Slow Leak Down for the Highest Spring Pressures
http://toplineauto.com/wp-content/up...y-postcard.pdf
Old Jun 24, 2020 | 07:55 PM
ROCKOUT Rocker Products
Sponsor
Get your HyLifts from WFOLarry Johnson Hylifts Ask him which ones you need
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 25, 2020 | 10:15 AM
TedMan's Avatar
TedMan
.....or call AMS Machine in Texas. They can help, as well.
Old Jun 25, 2020 | 12:39 PM
BB.No8's Avatar
BB.No8
I think YankeeDog had a post awhile back on this topic with a link for Johnson Hylift. This is a discription of different lifters type for Johnson Hylift. I could not find the link that I used to have but here is a copy that I saved onto my computer. Hope this helps.Types of Hydraulic Lifters:
Hydraulic Lifters are great for a maintenance free valve train but do have some limitations. In some performance applications where higher valve spring pressure is required, a standard Hydraulic Lifter might not be able to handle the extra spring load resulting with the piston collapsing. The collapsing will cause a loss in valve lift and usually a ticking noise. We have three different types of Hydraulic Lifters to accommodate a wider range of performance requirements.
OEM Design: These parts don’t have any designation after their part number. So a standard part number will look like A-0817. These Lifters are manufactured to be direct replacements of the Original equipment. They have the same range of Leak Down as was supplied to your car manufacture. These lifters are made with the widest Leak Down range of 10 to 120 seconds. The reason for this range is to ease manufacturing and reduce the cost of the part. We manufacture this type of parts to the same range as was supplied to the OEM with 90% of them being in the 20 to 80 second range.
“R” or Race Design: These parts have an “R” designation after their part number. So a Race Design part number will look like A-0817R. These Lifters have a Leak Down on the lower end of the scale from 8 to 20 seconds. In the performance application these lifter will actually “Bleed” down and result in an effective loss of valve lift and duration at lower RPMs. These are also referred to as “Variable Duration” Lifters and will supply a better idle quality when using a performance cam while still getting the benefit of the upper end power over a stock cam. As the engine increases in RPM the Bleed down effect is reduced resulting in more duration and valve lift. Having lifters with a much smaller Leak Down range will also balance all of the cylinders to each other. Having one cylinder with lifters having a Leak Down of 80 seconds will react and produce a different power curve than the same cylinder with a 10 second Lifter.
“S” or Slow Design: These parts have an “S” designation after their part number. So a Slow Design part number will look like A-0817S. These Lifters have a Leak Down on the upper end of the scale from 90 to 120 seconds. In a performance application these lifter will actually act like a mechanical lifter with very little effective loss of valve lift or duration at any RPM. Just like the “R” Lifters these have a much smaller Leak Down range that will also balance all of the cylinders to each other. These lifters are very hard to produce because the TOTAL clearance between the I.D. of the Body and the Piston assembly is reduced to less than 0.000120”, or 1/30 of a human hair. These are like super heavy duty shocks and can handle higher spring pressures without collapsing like the standard and “R” lifters. The only draw back of this type of lifter is that if the valve train should “Float” because of reaching a higher RPM than the valve springs can handle these lifters will try to take up the excessive clearance causing the valve to hang open resulting in a loss of power. Because these are Hydraulic lifters there is no lash or additional adjustment needed and the full cam profile is translated to the valves. In testing, not only did these lifters result in more power and higher RPM reading over other Hydraulic lifters they also reduced valve train wear and failure compared to mechanical lifters.
Old Jun 25, 2020 | 01:01 PM
LQQK_OUT's Avatar
LQQK_OUT
After reading a bunch of threads about lifters, I just ordered the B2303S Hylift Johnson lifters from Amazon. $116 for a set of (4).
Old Jun 25, 2020 | 01:12 PM
BB.No8's Avatar
BB.No8
Your good.
Old Jun 25, 2020 | 09:32 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you didn't increase your spring pressure, standard lifters are all you need. Slow bleed lifters are for higher spring pressures. And remember the lifter is actually a pump that sends the oil up to your rockers so if you have a slow bleed rate you're going to send less oil up to the top end unless you have higher spring pressures with the valve on the seat and then valve open.
Old Jun 26, 2020 | 04:46 AM
Yankee Dog's Avatar
Yankee Dog
I am on season number three with mine. No issues at all. Quiet, smooth.
Just don't make the same mistake i did...make sure you soak, fill, pump, etc oil them up good before install. I did not!
After starting up with my fresh top end rebuild, they made noise. Thought I screwed the pooch with the rebuild. I posted the issue here and was talked down from the ledge.
Was encouraged to "run it" as those with more experience and knowledge than me picked right up on the issue. Took awhile for the lifters to pump up and quiet down. Like 15 minutes but seemed forever. Funny thing is, the noise sounded like it was coming from the left side of the engine.Used the stock pushrods, even with .010 trimmed off the cylinders and a .030 head gasket. I will definitely use them again. Good value. YD
Old Jun 26, 2020 | 05:37 AM
LQQK_OUT's Avatar
LQQK_OUT
Are you saying it's a mistake to use the B2303S (slow leak down) on a basically stock EVO?
Old Jun 26, 2020 | 07:07 AM
98hotrodfatboy
No.. they'll be fine just not necessary.. I doubt you'll be running 6500 rpm..
