Rocker covers
Old Jul 17, 2020 | 10:36 AM
SirHarley's Avatar
SirHarley
Never use sealant on any gasket. Let the gasket do the work, or fix the issue. A temp fix would be okay I guess, but once you start the slippery slope of fixing thigs with silicone sealant and rubber bands...Well...Use James Gaskets, they are the best in the industry.
Old Jul 17, 2020 | 10:50 AM
t150vej's Avatar
t150vej
Just called local dealer (Savannah HD) and they were still available, but are listed as "Pending Obsolete", so I bought a set...
So when then they sell out of stock, they're gone. Last time I checked several months ago, the old ones were gone and the new ones were still a good number. Ronnies showed them all n/a, is where I got my incorrect info.
Good purchase in the nick of time. Congrats!
Old Jul 17, 2020 | 12:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
With over 50 years experience as a mechanic (44 as a licensed A&P mech) I disagree with that one size fits all statement...
I use sealant on a lot of gaskets (Hylomar).
There are many applications where a sealant is not needed, but it just helps make the job easier, such as holding a gasket in place during assembly.
The Hylomar doesn`t harden, and when it is time to replace a gasket, it will not be stuck (embedded sometimes) in the aluminum.
Easy to say fix the issue, but a lot of the stuff some of us work on is impossible to find parts for.
Old Jul 17, 2020 | 05:30 PM
WesternNSW's Avatar
WesternNSW
Love the Hylomar...
Old Jul 17, 2020 | 06:11 PM
nibroc's Avatar
nibroc
I second that hylomar
Old Jul 21, 2020 | 12:20 PM
TedMan's Avatar
TedMan
Quick advice needed. Will the Hylomar work as well as the Aviation Form a Gasket. I have Hylomar. Thanks.
Old Jul 21, 2020 | 12:32 PM
t150vej's Avatar
t150vej
Two totally different animals.
Had a very bad (and very expensive) experience with Haylomar years ago, so I won't speak to that other than to say, it's thin stuff. Plain grease or RTV works as well for the few things I'd even consider it for. Just my opinion.
Aviation Permatex however, I can speak to. It's for putting things together that you hope and pray will never need to be disassembled again. Works great for sealing cork from gasoline (like a tank float) and is impervious to everything including steam. Only thing that will degrade or thin it before or after curing is denatured alcohol. If you glue your rocker covers down with that stuff, better than even chance you'll need a hammer, thin chisel and utility knife to even get them apart and you'll be cleaning for days to get it off the chrome parts.
Stick with clean and dry for the rocker cover rubbers. If you're using the old style (fiber) on the lower housing to head gaskets, then most anything is good. If they're the rubberized metal - dry only.
I'll stand by my recommendations on the rocker covers, but will offer this disclosure on Hylomar before too many get bent out of shape. This came up on here, 12-14 years ago and without the long story, I used a NAPA Hylomar brand in a tube and it's quite possible I got something mis-labeled or even a bad batch. It squeezed out and had the consistency of Prussian Blue Marking Compound. Thin, runny and barely stuck to anything... used it anyway on request of a customer and ended up splitting the cases (again) and having to re-seal the halves and the oil pump as well. Hot oil washed it out, best I could tell. Again, a lot of guys sing praises of it, but never again for me.
Old Jul 21, 2020 | 01:49 PM
TedMan's Avatar
TedMan
Thanks for the info.
Old Jul 24, 2020 | 11:07 AM
TedMan's Avatar
TedMan
Just wanted to report back that I replaced the aftermarket rocker cover gasket with Harley OEM (updated version -92A) and took scoot for a 120 mile jaunt. No leaks! Thanks all for useful suggestions and advice.
Old Jul 24, 2020 | 12:10 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Hylomar comes in at least 3 different consistencies, the only type I used in the aviation engine world was the thick type.
Always let Hylomar dry for at least 15 minutes before assembling the parts.
The main reason I use it is that it holds the gasket in place, and even better, it makes the gasket much easier to remove vs installing a gasket dry.
As you say, it`s definitely not for sealing crankcases...
