buddies dad gave me forward controls off a softail said they would fit
Old Sep 13, 2020 | 06:48 PM
robwlf10's Avatar
robwlf10
Default buddies dad gave me forward controls off a softail said they would fit
so my buddys pop gave me 3 inch stretch forward controls off his 92 said they fit 86 to 99 softails..
no master cylinder said i either have to flip mine or get one that mounts onto the lower frame, im guessing on that lower square near mid frame
ill post a pic... cause looking at my master there's no way the rod can go into the master. my fluid line is front facing and the plunger is in the rear
i mean there in really great shape ill change the pegs of course but, for free ill get whatever it takes to make them work .
wanted to get rid of the boards anyway as im always stretched out with my heels on the tops anyway
any help would be appreciated o there going on a 98 fatboy
Old Sep 13, 2020 | 07:11 PM
TwiZted Biker's Avatar
TwiZted Biker
Should bolt up to the frame no issues, pipe clearance is the only if depending on the system.
Old Sep 13, 2020 | 07:16 PM
robwlf10's Avatar
robwlf10
has vance and hines 2 into 1
ill have to get a pic of my master cylinder cause its reversed no way that rod is going on to it
back of the brake arm just pushes from the back of the master unless i flip the master around
i just dont want to take the bike apart and be like **** i need a master lol
shifter side im not worried
Old Sep 14, 2020 | 12:48 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yeah that's not gonna fit a Softail. The master cylinders up front in front of the floorboards.. That's for like a mid-glide mid-controls type master cylinder, like on a Dyna...
Old Sep 14, 2020 | 01:02 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
An FXSTC (which comes with pegs) comes with a different style MC that has the reservoir mounted between the down tubes than the FL's ( the ones with boards) which have an all inclusive MC/reservoir combo mounted towards the inside front of the right hand board.
Basically what I'm saying is you need to get a new MC and reservoir to run pegs on your Fatboy.
Old Sep 14, 2020 | 01:04 PM
texashillcountry
Dirt don't hurt
Just out of curiosity what are your plans for your boards and MC after you do the change?
I like spare parts!!!!
Old Sep 14, 2020 | 01:08 PM
robwlf10's Avatar
robwlf10
i dont want them ....now i gotta figure out what master i need
and line i took the whole thing apart installed the shifter side went on like a charm soon as i got to the brake side im like ****
so i need a fxstc master and line ?
Old Sep 14, 2020 | 01:50 PM
texashillcountry
Dirt don't hurt
And reservoir.
As I said the reservoir is not part of the MC on an FX. It's attached to the down tubes behind the regulator and a hose connects it to the MC.
Old Sep 14, 2020 | 02:23 PM
robwlf10's Avatar
robwlf10
cool ty so does it matter what yr i found one oem on ebay think its a 92
Old Sep 14, 2020 | 02:31 PM
robwlf10's Avatar
robwlf10
pretty much this
