Bottom end breathing
Old Oct 6, 2020 | 08:49 PM
  #31
98hotrodfatboy's Avatar
98hotrodfatboy
On a wide glide, I'd probably use a 5. On a fat boy or an FLH a 6. On a Sportster a 3 or 4, depends on how much it's built..
Old Oct 11, 2020 | 07:17 AM
  #32
JDixon's Avatar
JDixon
Default Voes now working
Got a new hose and hooked up Voes. I works! I definitely was missing something major in throttle response. I'm just gonna repress all the thoughts of all the miles I put on with it not running properly.
It does run slightly rich feeling though. I had taken the bike to an indy shop for a leaking tappet block and had mentioned see what he thought of the tuning last year. Apparently he didn't notice the voes issue but had mentioned he worked on the pilot jet.
I'm thinking he changed it. I got the standard 25 on order. I think a simple swap out will bring it back to life even better.
Old Oct 11, 2020 | 07:27 AM
  #33
98hotrodfatboy
Just so you know I'm running a HSR 42 on a 89 stroker and the pilot is only a 22.5 and it's extremely snappy...
Old Oct 11, 2020 | 08:31 AM
  #34
JDixon's Avatar
JDixon
Good to hear! I'll keep that in mind when I get more into it. Thanks!
Old Oct 11, 2020 | 05:13 PM
  #35
98hotrodfatboy
Update from my previous post about the 22.5 pilot on HSR 42.. sometimes memory fails me.. The 22.5 is on my toolbox so obviously I'm running a 25, my bad sorry about that. Memory doesn't always get me there..
Old Oct 21, 2020 | 09:39 AM
  #36
JDixon's Avatar
JDixon
When you change your mikuni pilot jet, do you have to adjust air/fuel mixing screw each time??
Old Oct 21, 2020 | 12:43 PM
  #37
98hotrodfatboy
Yes..... You know you're close to the right size pilot when you're mixture screw is one and a half to two turns out...
Old Oct 22, 2020 | 07:14 AM
  #38
mike131's Avatar
mike131
I cant believe he didn't notice the timing not advancing when rejeting a carb?? and then checking the voes switch??
Old Oct 22, 2020 | 07:16 AM
  #39
mike131's Avatar
mike131
but I'm glad you got her fixed!!
Old Oct 22, 2020 | 03:49 PM
  #40
JDixon's Avatar
JDixon
I wasn't the one messing with the carb. A shop here in Maine missed it. NOT taking it back to them
