Road King problem!!
Old Nov 3, 2020 | 06:06 PM
eighteight's Avatar
eighteight
plenty of choices out there, pick your preferred material, grade, head type, finish etc
local supplier, Grainger, Fastenal, McMaster-Carr
Old Nov 3, 2020 | 06:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Mattbastard
I've had so many OEM 1/4"x20 Harley fasteners break it's not even funny. Yes I take stuff apart repeatedly which I'm sure deforms them a little bit each time, but still, it's enough to replace everything with SS or Gr.8 wherever I see a need.
Harley 1/4-20 fasteners are grade 8.
Harley fasteners may not be good looking, but they are quality fasteners.
Old Nov 4, 2020 | 02:05 AM
Mattbastard's Avatar
Mattbastard
False. On my 96 Sportster and 94 Evo Road King the rocker box bolts that were 1/4"x20 didn't even have markings on the tops. The Sportster ones broke torquing them down (on the light end of the scale, BTW), and on the Evo those got swapped out to Gr.5 because that's what I had lying around and I didn't trust the OEM ones. I've also broken many primary cover bolts just wrenching them down with a T-handle allen wrench.
Oh, and also on V-Rod I had a few years ago the upper shock bolts, the 1/2"x13 bolts, were bent. Presumably from normal use, but still, BENT 1/2"x13 bolts!!!!! Go see my thread about it, it's around here somewhere.
Harley fasteners are ****. Any time a manufacturer can buy THOUSANDS of something they're gonna cut as much cost out of each one as possible.
Old Nov 4, 2020 | 05:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Never heard of someone having so much trouble with Harley fasteners breaking, you must get all the bad ones......
Old Nov 4, 2020 | 06:12 AM
EVOrider's Avatar
EVOrider
He’s getting the bolts made on Mondays and Fridays....
Old Nov 5, 2020 | 02:09 AM
Mattbastard
I think it had a lot to do with them being tightened a bunch of times in their lives. I had those engines apart a lot...
Old Nov 6, 2020 | 09:28 PM
soupman77's Avatar
soupman77
So, I’ve picked a set and spare set of OEM HD bolts...however, now having issue locating the original torque specs for the 94. Anyone have knowledge they can pass on? “Tight and a bump” got me in trouble the first time...well, that and old bolts + 18 ftlbs...
Old Nov 7, 2020 | 07:32 AM
EVOrider's Avatar
EVOrider
I can look in the factory service manual this afternoon unless someone else chimes in.
However, I don’t use the torque settings on primary cover bolts. I use a ball end Allen screw driver type....one hand only. Never a problem.
Old Nov 10, 2020 | 07:56 AM
soupman77's Avatar
soupman77
I was able to get some extra primary cover bolts...but still don’t have torque specs, and a manual that I had, doesn’t cover 94’ RK. Does anyone have the torque specs ft/in lbs?
Old Nov 10, 2020 | 08:19 AM
0maha's Avatar
0maha
I don't know what the manual says, but for a 1/4-20 bolt, and assuming they are at least Grade 5 which they should be, you'll be fine at 75in-lbs.
