SEH-57 Cam in my Evo
Old Dec 17, 2020 | 02:50 AM
TimJ2110's Avatar
TimJ2110
Default SEH-57 Cam in my Evo
Hi,
I pulled my top end apart the other day. And to my delight i found a set of domed KB pistons:-)
The pistons are stamped with 266 and KB.
The heads are stock, but the valvesprings are upgraded too much beefier ones.
The cam is a SEH-57 cam, witch after som research I understand its a Screaming Eagle cam... Havent understood the reason for the H though, since all I can find is SE-57 but...
Is this a good cam for the setup of pistons I have?
Im planing on putting on some ported heads with altered combustion chamber.
I was told that the bike had a 1450 high comp kit when i bought it.
It pulls much stronger then a stock EVO for sure, but not sure if its built for high RPM or what with that cam. The bike will be dyno´ed as soon as the engine is back together.
Any thoughts on what to expect and if I should alter som more things to make the bike a little bit more fun:-)
Old Dec 17, 2020 | 07:51 AM
98hotrodfatboy's Avatar
98hotrodfatboy
That cam is a top end cam.. with a 50* ivc it would require 10.5-11.0 Static compression.. Without a good set of heads your leaving a good amount of power on the table..
I think you need to start with measuring the bore and stroke so we can make a more accurate assumption.....
Old Dec 17, 2020 | 10:10 AM
eighteight's Avatar
eighteight
[QUOTE=98hotrodfatboy;19605370
I think you need to start with measuring the bore and stroke so we can make a more accurate assumption.....[/QUOTE]
This
1450 is 88 ci
Dont think stock evo cylinders stretch past 85 cubes w/o changing the stroke?
Old Dec 17, 2020 | 10:35 AM
98hotrodfatboy
This
1450 is 88 ci
I said what I said because the OP obviously doesn't know what's in the motor he just got this bike apparently because he stated to his surprise he's got domed pistons. So based on that he needs to check everything that's all I'm saying.. How can he possibly know how many cubic inch the motor is by looking at the dome of a piston? AND..... There's no way the heads are stock if he's running a .576" lift cam in an Evo motor.. stock heads can handle safely maximum .515-.520.... MAX...
Old Dec 17, 2020 | 10:37 AM
TimJ2110's Avatar
TimJ2110
Hi, thanks for the reply.
I have read that the 266 pistons from KB is rated for 10.5:1 compression in a otherwise stock EVO. So with the new heads that have an altered combustion chamber, Im guessing we are close to 10.7-10.8:1
I will take some photos of the new heads tomorrow.
Old Dec 17, 2020 | 10:40 AM
TimJ2110's Avatar
TimJ2110
So what you are saying is that there is no way my engine would survive with this cam and the 266KB pistons only?
The seller told me 3 years ago that this was a 1450engine with high compression pistons. I also have compression release valves on the heads.
Old Dec 17, 2020 | 10:48 AM
98hotrodfatboy
With stock heads... That is correct.. coil bind definetely and possible valve to valve clearance issues...
Old Dec 17, 2020 | 10:58 AM
TimJ2110's Avatar
TimJ2110
Hmmmm, must be a miracle then Since i have been running the engine for 3 years now... The only thing my buddy (who is a Harley tech) noticed is that the valve springs are upgraded.
Old Dec 17, 2020 | 11:02 AM
eighteight's Avatar
eighteight
I said what I said because the OP obviously doesn't know what's in the motor .
And I was absolutely agreeing with you and asking for confirmation ( hence the ? Mark)
because I acknowledge your evo knowledge.
no slight intended nor implied!
Old Dec 17, 2020 | 11:06 AM
98hotrodfatboy
I must have taken it the wrong way.. I will be more careful..
