92FXRS Electrical Help
Old Feb 28, 2021 | 12:18 AM
Brycen's Avatar
Brycen
Stage I
Default 92FXRS Electrical Help
Doing a full drame off restoration on my dads 92 FXRS. Its almost done but have a hangup on the electrical, particularly turn signals. Everything was removed from the frame for sand blasting and paint so turn signal wiring was cut and reconnected by soldering and shrink wrap. Able to trace power to rear turn signal socket, heres the challenge:
Turn signals are original with brand new bulbs. With rear bulbs in the lamps, when pressing the turn signal buttons, nothing happens and the indicator lights on dash dont turn on. With the rear bulbs removed, pressing turn signal buttons causes front bulbs to light up, indicator light turns on but does not flash, then I insert rear bulbs and indicator light turns off and it repeats.
anyone have any ideas?
Old Feb 28, 2021 | 06:34 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Load test the battery...
What do you mean by "and it repeats"?
Old Feb 28, 2021 | 07:29 AM
Taggs's Avatar
Taggs
Check for secure, paint free, clean ground connections.
sporti
Sep 12, 2024 12:10 AM
Raypat
Mar 2, 2020 08:13 AM
Winston74
Electrical/Lighting/Alarm
Feb 17, 2015 06:24 PM
Seth64
Oct 15, 2012 09:38 PM
1911man
Aug 23, 2012 12:22 AM
