help ign. won't turn
Old Jun 14, 2021 | 04:52 PM
im's Avatar
im
TURN handlebars full left.
While Handlebars are turned full LEFT...PULL back towards rear tire hard just on the left handlebar grip and HOLD while pulling.
Then while pulling the handlebar grip try turning the key lock.
Reason:
Sometimes the rubber doughnut/ foam rubber/ fork stop rubber ring thing (pick a name)... gets hard and does not allow lock to set or gets it stuck.
AND
If for some reason somebody worked on front end of the bike and spun the ring around the indent/crease created after many years then it will not be on lock side and it WILL push handlebar away just enough to present a problem.
Old Jun 14, 2021 | 04:59 PM
im's Avatar
im
Old Jun 14, 2021 | 06:04 PM
Dr.Hess's Avatar
Dr.Hess
From the video, I wonder if you didn't have the gas tank on there if you could get to that release button in any position, not just the lock position.
dynamac
Jun 30, 2018 05:46 PM
Ultra61
May 13, 2008 09:10 PM
Marksman
Apr 7, 2008 02:19 PM
eddieflyer
Mar 26, 2008 01:11 PM
joshski7
Jul 21, 2007 09:47 AM
