Slipping Clutch. ‘97 FLHTC
Old Jul 20, 2021 | 04:39 PM
Dano523's Avatar
Dano523
Originally Posted by Pgh-mike
Can you tell me what parts I will need to get to update, and where? Also plates.
Walk in the park,
Need a HD spring compression tool,
Amazon Amazon
Your going to thread off the center acme adjuster rod with lock bolt, thread in the rod that comes with the tool, then us it to compress the clutch flat plate spring so you can remove the outer C clip.
Huge note, and at 3;00 in below video, the spring plate rivets are falling out in his hand, and should have replaced the spring plate at that point.
As for if just replacing the spring plate if you have no damage to the basket of plates, pretty much straight forward. Hence take the time to pull all the plates, and make sure that there is no loose rivet damage to the clutch basket or parts.
If you are going to go with a extra disc clutch, then read the directions so you install it correctly, including the inner replacement rings as well.
As for adjusting the clutch once you have the clutch parts reinstalled,
Note, now is a good time to check your primary chain adjuster.
As for primary cover, use a new gasket, and make sure to torque the bolts correctly and in the correct order.
Old Jul 21, 2021 | 06:58 AM
flhchaz's Avatar
flhchaz
Also pay attention to where the bolts come out of the Primary cover, some are longer than others. Put them back in the hole they came out of.
mgmmgm
Dec 23, 2023 10:38 AM
bladeguy
May 20, 2021 09:36 PM
cvaria
Apr 21, 2017 12:08 PM
texacon
Jul 18, 2011 07:32 PM
Pippeis
May 27, 2006 12:36 PM
