Not sure of age or miles on this clutch. It just started slipping last weekend, also hard to get in neutral. I have done many repairs on bike but never a clutch. Is this a job I want to tackle?
Yeah you can do it. Common problem is that there is a spring plate in the clutch pack the grenades and jams everything up. When It happened to my '97 FLHT, I replaced the clutch pack with the screamin' eagle that has the extra plate and does away with the spring plate. You will need the tool to compress the spring to get it apart. I have one and am in Munhall, you can borrow it if you'd like. do you have a factory service manual?
Its called the clutch spring plate (think judder spring), that has brass rivets, and the rivets will crack, come out of the channels, and cause the problem.
Catch the problem quick enough before the loose rivets and parts do much damage, and you can just replace the spring plate.
Better yet since you just pulled the primary cover and clutch apart to get to the plates, change out the clutch to an " extra plate clutch" that does not use the spring plate instead.
P.S, when you have the primary cover off, check the spring washers on the comp as well. If needed, you can replace just the concave washer type springs on the comp, instead of having to replace the entire comp.
