I have an LED brake light I ran in my previous Twin Cam bikes that I want to use on my 1995 FXDS. It's one of those really bright lights that flashes 3 times then goes solid when you hit the brakes. By the way its just a bulb that replaces the stock bulb.
I put it in the socket and hit the brakes and there is a delay and then it flashes once and goes off even if I hold the brake lever. Any reason this wont work on an Evo?
If you just jumper wires from the battery to the "bulb," what happens? That is, one wire on the outside of the base to ground, then either touch the center to the + or run another wire. Does it behave as expected or as observed on your new bike?
Ive run this same style bulb in 3 other non CANBUS bikes without a problem.
It just dawned on me that maybe the bulb its self is defective. I have a couple of these in my tool box, Ill try a different bulb and see what happens.
If you figure it out, please let me know! I have been looking into the cluster replacement options (brightassleds) and just haven't pulled the trigger.
I did just narrowly avoid another rear end accident while at a complete stop at a red light.
Not sure if a brighter light will help me be seen more, but it's a little piece of mind and something to do!
