First plug change - requesting comments please
Old Oct 25, 2021 | 12:55 PM
mike131's Avatar
mike131
The pipes don't look too bad, if the bike just sat round and idled, on those plugs I wouldn't worry about it yet, run the bike on your new plugs then check it, excessive idling isn't good for an air cooled engine
Old Oct 25, 2021 | 01:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
As Mike131 said, I wouldn`t worry too much about the plugs, put some miles on the bike.
Plugs are hard to read with todays fuel and ignition systems, my bike (89 Evo Softail CV carb) was running rich (33MPG) because of an issue with the enrichener, but the plugs looked perfect...
Old Oct 25, 2021 | 01:38 PM
t150vej's Avatar
t150vej
I agree. Don't start chasing a problem that may not exist. Plugs will always smoke up on a cold start, especially the rear. It takes some miles under load for them to get hot enough to "self clean" which they are designed to do. With these modern ignition systems, actually fouling a plug to the point of misfire is basically non-existent, absent of a major issue.
But from the looks of those plugs... if you put new ones in, ran them several hundred miles and they look the same, I'd wager someone put a shim under the needle. All that does for a normal road bike is ruin your fuel mileage and turn your plugs reddish orange.
Old Oct 25, 2021 | 01:43 PM
GREENOHAWK69's Avatar
GREENOHAWK69
I would pull the carb and go through it so you can see what's in it and figure out if you have a problem or can rule it out as an issue.
CV carb parts: https://cv-performance.com/
Old Oct 25, 2021 | 01:44 PM
Super Glidester's Avatar
Super Glidester
First plug change since 98? man that's pretty good...
Old Oct 25, 2021 | 04:14 PM
carlgrover's Avatar
carlgrover
Those plugs look oil fouled to me. You say you oiled your plug threads before you put them in? How much oil did you use? I wouldn't touch the carb for now. Put a new set of plugs in it (no oil on the threads) and put some miles on that thing. Pull the plugs after 5k miles and then see what they look like.
For what it's worth (probably nothing in an EVO thread) I've had to replace a bad plug or two on my ironhead in the past. ALWAYS carried one on a two stroke dirt bike. It won't hurt to carry a spare.
carl
Old Oct 25, 2021 | 04:36 PM
Pale Horse Rider's Avatar
Pale Horse Rider
Thanks for the advice everyone! Ride it I will!
GusTrevino
2018+ Softail Models
11
Nov 16, 2020 09:32 PM
Noodelz666
11
Jun 22, 2020 05:41 PM
byronk
EVO
Jul 9, 2015 08:06 PM
jrb1449
Carburetor Related
Jul 1, 2014 10:13 PM
inswva
Oct 22, 2010 07:20 PM
