Upgrading inner fairing
Old May 9, 2022 | 09:52 AM
t150vej's Avatar
t150vej
Originally Posted by Schex
That was from a 84-90 FLT-FXR fsm
OK. They must have still been using the Shovelhead gauges in the earlier FLT. Thanks
Originally Posted by Idiocracy
its a 75032-99b. DAMNIT. Thanks everyone for the help in chasing this down. Turns out Im the bonehead.
Glad you found a number on the current gauge, that explains it all. Don't know if the sender for that one would look very good and you'd have to change the wire ends to connect to it.
Old May 10, 2022 | 12:31 PM
Idiocracy's Avatar
Idiocracy
Yeah, the sticker was faded but I could make out the -99b suffix. Pinwall will have the right one here on Thursday. Thanks for all the help, no way I would have gotten this resolved this quickly without it.
Old May 10, 2022 | 01:04 PM
t150vej's Avatar
t150vej
Schex and rizzo are up on fairing particulars much more than myself, and it was Ya Tigor who actually called it. I was going on assumption you were using a non-TC gauge. Wealth of information on here and I learn at least as much or more than I (think I) know
That's quite a project you took on and it's looking fantastic. Kudos
Old May 10, 2022 | 02:07 PM
Idiocracy's Avatar
Idiocracy
Agreed. I owe a bunch of people some beers for the help on this. I'll post up when its all complete. Hopefully this weekend.
Old May 14, 2022 | 04:14 PM
highside71's Avatar
highside71
new to the Harley world and I have a 95 ultra classic, is that a factory batwing? and what radio is that?
Old May 18, 2022 | 07:13 PM
Idiocracy's Avatar
Idiocracy
Default Finished!
Amazon outer fairing painted brilliant silver from PaintScratch.com
Metra 95-HDIF inner fairing. Highly recommend.
Led bulbs. Sony AX5000. DS-18 6.5 neo marine speakers. Pyle 400w amp. Loud as all hell!!!
Old May 18, 2022 | 07:17 PM
Idiocracy's Avatar
Idiocracy
That outer batwing is from Amazon. The inner is from Metra. Radio is a Sony XAV-AX5000.
Old May 20, 2022 | 07:54 PM
WhiteBoysEVO's Avatar
WhiteBoysEVO
6th Gear
Where did you get the inner fairing as a double din? Did you swap to electronic speedo?
Old May 20, 2022 | 08:14 PM
WhiteBoysEVO
6th Gear
What wiring harness did you use? Did you run a new fuse box? Did you remove all the old harness and old school fuses? I’m not sure what they are called but they aren’t fuses. More so like breakers?
Old May 20, 2022 | 10:03 PM
Idiocracy's Avatar
Idiocracy
Google Metra double din inner fairing, you'll find it. Stayed with mechanical speedo, that was there hardest to find. Has to be 96 or 97 only.
Kept all the original bike wiring. Just updated connectors to work with 96-98 gauges.
Cayo0764
Feb 26, 2017 06:11 PM
Hbombrider56
Jul 15, 2013 01:02 PM
EuroBird
May 15, 2013 09:32 AM
Casper
Feb 25, 2013 06:51 AM
the303hooligan
Mar 26, 2011 01:01 AM
