What is causing this?
Old Mar 17, 2022 | 02:55 PM
Hey Man's Avatar
Hey Man
Default What is causing this?
1993 FLSTC Heritage Classic.
First press on the start button, I get a delay and a whine. Second press on the button and it starts right up every time. It does it hot or cold.
What I've done so far that hasn't fixed it:
New battery
New starter
New relay
New cables
Checked cable resistance
New start button
New stator
New regulator
New ignition
Cleaned battery connections hot and ground
Cleaned ground connection to frame
Separated plug connections and cleaned contacts
Could it be a timing related issue?
What else can I look at? I tell ya, fugg these Evos
Old Mar 17, 2022 | 03:15 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Starter drive?
Griz
Old Mar 17, 2022 | 03:23 PM
Hey Man's Avatar
Hey Man
I thought about that but I doubt that I'd be that unlucky to replace a the old starter with a brand new one that was bad.
Old Mar 17, 2022 | 03:33 PM
WP50's Avatar
WP50
With all you have done.
That's exactly where I'd be looking .
WP
Old Mar 17, 2022 | 03:38 PM
TwiZted Biker's Avatar
TwiZted Biker
It's happened, be honest it sounds like a connection issue somewhere, start checking the small grounds like for the starter relay or the handle bar control's
Old Mar 17, 2022 | 03:51 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I would assume a new starter came with a new solenoid.
If it did, you got a bad one with the new starter.
The starter clutch is a sprag clutch. It locks up driving the motor. It only slips if motor starts and out runs electric motor which lets the rollers run back dow the ramps.
It doesn't slip. It's possible if the grease is dry and caked and rollers have the springs held down is slip position, it could slip but highly unlikely.
That hesitation is poor contact on the solenoid that applies the heavy amperage required by starter motor.
Old Mar 17, 2022 | 04:07 PM
daven9113's Avatar
daven9113
Can you describe more of the whine sound? Electrical or mechanical sound? Location?
Have your run larger gauge ground wire from the starter relay connector?
Old Mar 17, 2022 | 04:10 PM
touchdown's Avatar
touchdown
I was thinking something to do with the starter or solenoid, but after checking everything that you do maybe time to trade it in on a new one.
Old Mar 17, 2022 | 04:58 PM
FreedomRider's Avatar
FreedomRider
try jumping the solenoid and if that cranks add the second relay ...
Old Mar 17, 2022 | 05:02 PM
carlgrover's Avatar
carlgrover
What brand starter did you buy? Wasn't all ***** was it? Whine to me sounds like the starter isn't engaging the ring gear on the clutch.
carl
