Evo pinging
Maybe a rip to a good tuner who deals with e Power Commander and let them look at the map for that setup.
Griz
Pressure and flow rate, since a fuel filter that is staring to clog up, may give you a good static pressure check at the bunge, but bottom will drop out as it's trying to flow fuel at that pressure.
Also, double check the system on the return side as well, since could be problem in the pressure regulator causing problem too.
Which aftermarket filter is the best?
A rather simple system.
It reads as if bike had work done BUT it was running well until it was pulled out of STORAGE last time.
Based on information provided, it reads as if fuel or air has changed from before storage.
In 1997 the M & M fuel injection had TWO exterior fuel lines under the tank.
Those lines can leak at the swivel or fall apart internally but the Good Ridge HD-FL005 are a good replacement.
The interior tank liner can release and block fuel filter sock too.
The manifold seals (2) and cost about $10 total can leak and allow unmeasured air to enter too.
Any ideas on a fuel filter replacement if needed?
Note on the Quantum fuel pump, it's shorter than the HD unit, but if you use parts off the stock unit to shim/hold the new one down on the factory bracket, works fine.
https://www.jpcycles.com/product/166...uel-filter-kit
Note, double check on prices, but you can pick up a new filter, fuel pump, pressure regulator, and even tank cork bunge gasket "kit" for under $100 as a combine kit.
And double check your intake manifold rubber gaskets to the heads. If they are older then three years old, they have heat dried out and allowing air to leak past them to cause the motor to run lean. The dead give away that they are leaking, is back fire during decel that was not a problem before.
Myself, they get changed out every three years like clockwork, even with lubing the hell out of them with silicone grease during the install to slow the rubber from drying out in the first place.
1. Look down in your tank with a flashlight and see if there is anything flapping around (that would be your tank liner). Move the bike around a little to make it easier to see.
2. Replace your cork tank gasket and those 22 screws when you put in the new fuel pump and filter.
3. Check the "Y" crossover tube on your exhaust. They sometimes crack and cause a leak. This can be your decel popping.
carl
