'92 Fatboy shifter issues
Old May 30, 2022 | 10:39 AM
Anryan2's Avatar
Anryan2
Stage III
Question '92 Fatboy shifter issues
If this has been asked over and over again then point me in the direction of those threads but about a week ago I noticed that my shifter on my Fatboy wasn't returning. I called a couple of speed shops around my area and they told me it was a shifter pawl spring that had broke on me and that it would be a stupid expensive fix for a tiny little spring. how hard of a fix is it actually or do I have to make the walk of shame to a speed shop?
for better clarification I have a heel toe shifter but only use the toe end. when I push down to downshift it doesn't come back up and when I lift it up to upshift it doesn't come back down
Old May 30, 2022 | 10:46 AM
Yankee Dog's Avatar
Yankee Dog
Here ya go:
https://www.hdforums.com/forum/evo-c...wl-spring.html
Been a few recent threads about this also.
Old May 30, 2022 | 02:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Disconnect the shift rod at the transmission shift lever.
Make sure the transmission lever is tight on the shaft, no wobble at all...
Check that the transmission lever springs back to a centered position when you push it forward or rearward.
Check the front shift lever for freedom of movement (linkage disconnected).
Saltyvet77
May 31, 2017 06:28 AM
cdremy
General Topics/Tech Tips
Apr 2, 2017 07:35 AM
2011 fatee
Jul 4, 2014 03:08 PM
bkrhoades
Apr 27, 2014 05:01 PM
1931jamesw
Aug 25, 2010 04:39 PM
