Toe heel shifter.
Old Apr 6, 2014 | 02:35 PM
bkrhoades's Avatar
bkrhoades
Default Toe heel shifter.
Ok, I just bought a 2010 Fatboy a couple of weeks ago. My problem is that I cant seem to get used to using the toe heel shifter. I usually just use my toe. Am I the only one going through this small problem???
Old Apr 6, 2014 | 02:41 PM
mmcbeat's Avatar
mmcbeat
I have had a toe & heel shifter for so long that it would be hard for me to ride without it. But a lot of folks don't care for them. Nothing wrong with just using the toe only, you can leave the heel shifter in place or take it off. Decorative caps are available to cover the shaft it you decide to take it off. Also, you might want to adjust it up or down a notch to two to see if it feels more natural.
Old Apr 6, 2014 | 02:43 PM
SYLM's Avatar
SYLM
Takes a little time to get used to. I didn't like them at first
Old Apr 6, 2014 | 02:47 PM
Mal74's Avatar
Mal74
I had never used one til I bought my 'new to me' 2002 Heritage. Once I got used to it I only use the toe shifter to downshift.
Eyeball Kid's Avatar
Eyeball Kid
I took my heel shift off after getting it caught in my pants leg/cuff at a stop.
I guess if I adjusted it to a different position that would help, but why bother!
Old Apr 6, 2014 | 02:54 PM
gusotto's Avatar
gusotto
Both Harley and Kuryakyn make a heel shifter that rotates 45 degrees back to allow more room. Especially for larger shoes.
I prefer the heel/toe shifter as it doesn't scuff the toe of my boots.
Old Apr 6, 2014 | 03:09 PM
stircrazy's Avatar
stircrazy
after years I still didn't like it either so I took it off and put the cap on the cover the exposed area on the shifter shaft.
Steve
Old Apr 6, 2014 | 03:13 PM
TracerBullet's Avatar
TracerBullet
Could not imagine riding without it. After you get used to it you may feel the same
Old Apr 6, 2014 | 03:59 PM
amasoniii's Avatar
amasoniii
Not a fan. I took mine off to have more room on the floorboard. I think it only originated to make the bike look like old harleys with the foot clutch.
Old Apr 6, 2014 | 04:07 PM
Uncle Larry's Avatar
Uncle Larry
Took them off both of my Baggers ... Size 14 boots need more room
