1998 FLHTCUI Speedometer/ Trip OD
Old Jun 3, 2022 | 03:44 PM
Tee&Vee's Avatar
Tee&Vee
Default 1998 FLHTCUI Speedometer/ Trip OD
Hey gang,
The trip odometer isn't working. I can reset it to zero and it will go to 19 miles. It stops there.
The speedometer is working and the odometer is okay too. Hopefully it is not a progressive thing!
Has anyone else seen this issue? I'm sure changing out the front wheel speedo drive will do nothing and I don't like throwing parts at issues.
In my search I've seen a few posts about a small shop that rebuilds them but I'm not that far yet. In fact I dread going inside the fairing and would upgrade the sound system as the Evo forum says; While yer in there....
Thanks!
Old Jun 3, 2022 | 04:35 PM
t150vej's Avatar
t150vej
It's an easy fix... if you have patience and spare parts. The middle and/or left wheel has a chipped dog and you'd need a junk speedo to rob for parts.
Otherwise, send it to a speedometer repair service. Almost any of them "should" be able to fix it. Powl's in Lancaster, PA has a good rep if there's not one closer to you.
You can run it like that long as you want, not gonna do any more damage.
Old Jun 3, 2022 | 06:12 PM
Tee&Vee's Avatar
Tee&Vee
Ok!
Thanks for the link. I did look them up and that's their business.
I was hoping you would have said to oil it up and it was fine.
I have a shovelhead speedo but that might be worth holding on to versus robbing it.
Dirty Dancer
EVO
17
Aug 11, 2021 12:03 PM
TXWarthog
EVO
14
Nov 13, 2017 09:56 PM
Rusty Axle
Shovelhead
Jun 21, 2017 09:34 PM
EVOrider
EVO
15
Aug 9, 2011 09:15 AM
wheeldawg
Aug 11, 2008 06:59 PM
