Front end wobbles…..😳😳😳
Old Jun 18, 2022 | 11:27 AM
sparky0496's Avatar
sparky0496
Default Front end wobbles…..😳😳😳
Ok guys new problem! I have a severe front end wobble above 75 mph. Just replaced tires and bearings front and back. My next starting place is neck bearings I think??? What else should I look into? I’ve got a big trip planed for Wednesday and need to get this thing tight. Thanks in advance!!!
98 Electra glide ultra classic
Old Jun 18, 2022 | 01:38 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Were the wheels properly balanced?
Ride safe!
Old Jun 18, 2022 | 03:38 PM
sparky0496's Avatar
sparky0496
Yep local shop did them. That’s why I’m thinking neck bearings???
Old Jun 18, 2022 | 04:22 PM
carlgrover's Avatar
carlgrover
Did you have this severe wobble before you replaced your tires and bearings or did it start afterwards?
carl
Old Jun 18, 2022 | 04:38 PM
sparky0496's Avatar
sparky0496
carl
started afterwards. I took the wheels to them not the whole bike.
Old Jun 18, 2022 | 04:53 PM
Dr.Hess's Avatar
Dr.Hess
All of my steering wobbles have been the steering neck bearing being too loose. Follow the directions in the FSM. I kinda stopped having problems with that (and going through drive belts) when I kinda stopped pulling the front wheel off the ground.
I would also, just for the hell of it, jack the front up and spin the tire. Is it round? Nothing major out of round? Does it stop in the same place each time? That is, seem out of balance?
Old Jun 18, 2022 | 04:57 PM
sparky0496's Avatar
sparky0496
Wowzers thanks I will do this tonight thanks for the insight! Everyone else thanks to you as well! This is by far the best place for answers! My service manual is great but you guys have the experience I don’t.
Old Jun 18, 2022 | 05:03 PM
WP50's Avatar
WP50
Don't be afraid or to hardheaded to re ck your on work also.
WP
Old Jun 18, 2022 | 05:06 PM
sparky0496's Avatar
sparky0496
Yeah I’m fairly new into everything so usually double check things I may have over looked something. I’ve been known to do that sometimes🤦‍♂️
Old Jun 18, 2022 | 05:18 PM
pgreer's Avatar
pgreer
Dr. Hess has some good suggestions to work with. I'd add to that to check the swing arm bushings too. It's a 24 year old motorcycle, so unless some of these things have been replaced as a maintenance item, it would be good to check them as part of the process of elimination.
Paul
