Won’t start
Old Jul 15, 2022 | 07:55 PM
Racepres's Avatar
Racepres
Got a decent quality volt/ohm meter??
this is Not rocket science... either bad battery, even if New!!! or faulty charging system..
Unless someone been "Fixing it"... Then, Who knows..
Old Jul 15, 2022 | 08:01 PM
brakeless's Avatar
brakeless
May be time for a solenoid rebuild kit. Easy to check, pull the cover. My guess is the contacts are fried.
Old Jul 16, 2022 | 08:39 AM
97dyna's Avatar
97dyna
Default Solenoid voltage present
Ignition switch on, I get the same voltage reading at the green wire location on the solenoid with the run/stop switch in both positions. No drop when the start switch is engaged (one click).
Old Jul 16, 2022 | 11:20 AM
t150vej's Avatar
t150vej
Originally Posted by 97dyna
New battery. Will start if and run if I jump positive to solenoid. Still just a click from the handle bar switch. I’m starting to chase it with a meter. Thx for your help.
The run/stop switch simply energizes the "start" button and ignition. There should be no voltage on the green wire unless the kill switch is on "run" and the "start" button is pressed.
If it starts with a jumper, battery to solenoid - with the switch and run/stop on (forget start button) and starter relay unplugged, jump across the #30 and #87 position of the relay harness plug. If it turns over, replace the starter relay.
Old Jul 17, 2022 | 08:03 AM
97dyna's Avatar
97dyna
Default Jumped 30-87
Jumped 30-87 on the starter relay plug and it runs. Heading out to get a relay. Hoping to get lucky and that’s the only problem. Great tip for someone trying to diagnose this problem!
Old Jul 17, 2022 | 09:42 AM
t150vej's Avatar
t150vej
Good deal.
Before you call it done - when you get the relay installed and starting properly, put your volt meter on the battery. When starting, it will drop to about 9.5 - 10.5 and when running it should raise to 13+ volts within a few seconds and climb to near 14 volts within 30 seconds or so, depending on the charge of the battery.
You clearly had a battery issue at the start of this but insuring the charging system it doing what it should might save a disappointment later.
Titan307
Oct 17, 2013 09:30 PM
BadMetal705
Dec 23, 2011 02:18 AM
mburnz
Aug 18, 2011 08:27 PM
frang413
Jul 14, 2009 12:44 PM
Modee1245
Mar 5, 2008 09:09 AM
