Evo head change
Old Oct 27, 2022 | 10:16 PM
mstrobes's Avatar
mstrobes
Default Evo head change
Can a top breather head be used on a older bottom breather motor? And if so will the rocker covers interchange.
Old Oct 28, 2022 | 06:59 AM
johnjzjz's Avatar
johnjzjz
Only difference is the thread for the air filter attachment we have the reducer to do that but can can use a 1/2 X 13 by 1 inch cheap bolt like the junk at lowes Home Depot - cut it around 1/2 inch long but drill and tap a 5 / 16 X 18 thread into the center - then hacksaw cut a slot for a screw driver for the install
do not red loc tite seen that its not falling out the air filter brace keeps it in place
doing it the other way more drilling and enlarging needed but both ways will work everything fits - the other way you need those rocker boxes for the different breathing
Old Oct 28, 2022 | 11:44 AM
daven9113's Avatar
daven9113
Yes. If you use non breather rocker cover assembly, you will definitely have to let it breath on the bottom. You can also let top and bottom breathe together.
Old Nov 3, 2022 | 08:24 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
When using late model heads on a case breather engine, don`t use the hollow bolts to mount the backing plate, use regular bolts to close off the breather.
You can use head breather rockers on a case breather with no issues, leave the umbrella valves out.
Old Nov 6, 2022 | 08:20 PM
Ozzie John's Avatar
Ozzie John
I have just rebuilt an engine that has both, im curious why do you need to take the umbrella valves out?
Old Nov 7, 2022 | 06:15 AM
johnjzjz's Avatar
johnjzjz
If the heads are umbrella and the block is down breather we use them as well so it has both going at the same time
garry c.
EVO
Aug 5, 2021 08:46 AM
Jonathan Green
Shovelhead
Sep 22, 2017 02:54 PM
Bdffry30
EVO
Dec 15, 2016 04:06 PM
Mountainkowboy
EVO
Sep 18, 2012 01:25 PM
jdbluedevils39
Exhaust System Topics
Dec 17, 2009 05:34 PM
