Evo Dyna Jackshaft Problem
A couple of weeks ago there was a crunching sound in my primary, literary as I pulled p to my house. I opened her up and sure enough the Jackshaft starter bolt had come unscrewed ands the lock washer was broken. Everything else appears to be fine so I figured it’s a simple replacement.
I ordered a replacement which was the “Spyke Bolt/Screw kit Item № 13-798” for Big Twins 1989-1993, length: 132 mm; thread: 1/4”-20.
When I try and replace the parts it turns out the new bolt and washers are much fatter than my original and the thread is different. Mine is a lot thinner. The new bolt head is 10mm and 65mm thick shaft and my original is 8mm bolt head and the shaft is 5mm thick.
I tried using their washers and lock nuts with my bolt as it wasn’t broken but when I tightened it there was a lot of slack/movement and to be honest when I put the tab into the Jackshaft there was so much movement that I don’t think it
Tab in the groove
Tab easily comes out of the groove
would stay there for a minute. You can see in the photos and video. It feels like there should be a sleeve in there?
So….any idea whether my original thinner bolts is “original? And more importantly should there be this much slack in the bolt?
Sadly I cannot afford to buy an aftermarket system which might be better.
You need the locking tab and sealing washer that matches your smaller diameter bolt. Order the locking tab and sealing washer for a 1994 model year. Use blue loctite on the threads of that long bolt in addition to the locking tab washer. Clean the threads bolt threads and the female threads first. That long bolt only uses very low tightening torque so go easy. I think like 7 lbs of torque.
Also not a bad idea to use hylomar on that tiny sealing washer if you care about keeping oil out of the starter motor.
I had a look again this morning and I wondered if the parts I received were from another year bike (as HotRod suggested, thanks) and sure enough when I searched the details for OEM 4358A these appear to be the size I have on my bike and they are for a 1994 onwards model, so I guess the PO had changed the Starter motor or Jackshaft section? I can now see if the washer fits my diameter bolt better and once its locked in on the notch this should hold it in place properly.
This also answers my question to HotRod which is that the thinner bolt is actually the more recent version, go figure.
Thank you gents....astounding forum!
