EVO engine case drip
Old Jan 24, 2023 | 01:10 PM
Omaha Derby Covers's Avatar
Omaha Derby Covers
Sponsor
Originally Posted by sbrmike
We get to -30F at times. We haven't for a few years though. A few years ago we stayed below zero for 11 days. That is cold enough to crack cases if too much moisture is allowed to accumulate.
I guess anything is possible, but I've never heard of an Evo case "cold cracking".
If I was in the market right now, a 25k mile, unmolested engine example would be exactly what I'm looking for.
Use the drip to beat him up on the price, of course, but I'd buy the bike with confidence.
__________________
Jeff Miller
https://OmahaDerbyCovers.com
Old Jan 24, 2023 | 02:40 PM
Schex's Avatar
Schex
A friend of mine's Evo had a seep, wet spot bottom center of the cases, I snugged the case bolts I could get to, cleaned it dry and it stayed dry.
Old Jan 24, 2023 | 03:09 PM
sbrmike's Avatar
sbrmike
I never said cold cracking. I said moisture (water) collecting in the bottom of the crankcase and that freezing and cracking the case. I would venture a guess that that could happen at +20F. I have seen car engine blocks destroyed @ +20F when they had water and no anti-freeze.
Old Jan 24, 2023 | 03:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You are not going to get a puddle of condensation inside the cases, it is just not reality.
Old Jan 24, 2023 | 05:50 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Make sure you get the Factory Service Manual and check your breathers.. To much positive crank case pressure will aide in seepage...
Old Jan 24, 2023 | 06:20 PM
pgreer's Avatar
pgreer
I know you said the top was dry, but the most common leak on EVO's is from the cylinder base gaskets. It's usually more of a seep and can get worse over time, but gravity along with heat and wind can move it around and accumulate making it difficult to diagnose.
Clean it really good and run it long enough to get it hot and circulate the oil. If it is the case halves leaking, tightening the bolts is not likely to help because there is no gasket or seal between the halves. They use a sealer. If you do have to reseal the case halves, hondabond is an excellent sealer.
Paul
Old Jan 26, 2023 | 02:08 PM
sbrmike's Avatar
sbrmike
Ok I checked it out real good; actually a blind man could have diagnosed it. The Transmission drain plug was loose. They just looked under the bike, neve bothering to peer upwards for the source! The cases were bone dry everywhere. The only oil anywhere was I am assuming from changing the oil filter; the front rubber mount area was oily - nothing fresh though.
I did notice on the Transmission bottom pan, it had what appeared to be two separate drain plugs. The leaking one was on the right side about center front and rear and the other was on the left side towards the rear. I know nothing about any 5 speed transmission, much less a 1998 5 speed. Did they have two drains for the Transmission or what does the other one drain? I can't see where there is a partition in that bottom pan of the Transmission.
This is a 1998 Wide Glide. My 1984 has either two drains or the drain is in two locations on 1984's depending on the model. I can't remember if I have two or not and I am too lazy to go look! LOL. Mine uses the rear facing drain, a 1984 FXEF 4 Speed Shovelhead. Some 1984 4 Speeds have the drain at the bottom of the Transmission like most other 4 Speeds.
Old Jan 27, 2023 | 08:30 AM
FLHRinFL's Avatar
FLHRinFL
Not sure about a Dyna but on the 1993 and up touring bikes, one drain plug is for the transmission and the other is for the engine oil.
Old Jan 30, 2023 | 09:01 AM
cycleman11's Avatar
cycleman11
You don't mention the year of EVO, but on my 98 this is the location of the drain plugs. I'm pretty sure they are the same for anything with a 5 speed. The drain plug for the engine is at the bottom right of the pan as you look from the oil pump side of the engine. The transmission drain bolt is on the left side of the oil pan and up beside the frame, again on the right side of the bike as you sit on the bike or on the left side as you look from the front to the rear of the bike. If you get a small mirror you can see them better. Glad you got your leak figured out.
MJHJEA
EVO
35
Mar 10, 2014 08:48 AM
paco
EVO
20
Nov 2, 2013 08:43 AM
streetg131
Exhaust System Topics
Mar 1, 2012 05:15 AM
brian burleson
May 26, 2010 10:53 AM
tweedy
Aug 9, 2005 01:18 PM
