Clutch basket
Old Mar 18, 2023 | 06:01 PM
86glider's Avatar
86glider
Default Clutch basket
Hey guys, I’m replacing my clutch plates and noticed there’s a bit of wobble when I grab the shell w/o the plates in place,I would say 1/8” play. Is this normal?
Old Mar 18, 2023 | 08:08 PM
WP50's Avatar
WP50
While that's not a lot I'd say No.
If the basket has rivets ck them. Seen it more than once
You need to establish where that looseness is at
WP
Old Mar 18, 2023 | 08:10 PM
TwiZted Biker's Avatar
TwiZted Biker
Read this thread,
https://www.hdforums.com/forum/evo/1...ff-thread.html
Old Mar 18, 2023 | 09:07 PM
Farm Shop's Avatar
Farm Shop
I’m assuming you are talking about the 86 that’s in your profile name? If your hub is tight but the basket has just a little bit of wobble with the plates out that’s normal in my experience. The single wide bearing in there will do that. The later clutches with the double row bearings in them are more solid.
Old Mar 19, 2023 | 08:03 AM
98hotrodfatboy's Avatar
98hotrodfatboy
An 1/8" is a lot.. Think your gonna have to take it all apart... That looseness will eventually take out the whole shaft as in the thread TwiZted mentions...
Old Mar 19, 2023 | 12:05 PM
t150vej's Avatar
t150vej
With that era clutch a 1/8" wobble, if measured at the inner to the starter ring, isn't that bad but is well worn for sure. With a brand new bearing, you'll be able feel a tick of play but not enough to easily measure.
With the outer already off, I'd pull the assembly, change the bearing and be done with it. Only takes a few minutes to press off/on after you get it off the bike and the clutch will work a lot better too.
Old Mar 20, 2023 | 05:21 AM
guido4198's Avatar
guido4198
I'd not put it back together until you KNOW where that 1/8" of slop is coming from. If it's part of the problem, clutch hub bearings are cheap, and easy to replace while you have it open already. Depending upon how many miles you have on the current one, replacing it might be a good idea regardless, but that's just me. I've been riding the same '85 since I bought it new and sometimes replace the easy, inexpensive things with significant miles "while I'm in there"...just because.
Old Mar 20, 2023 | 12:29 PM
Schex's Avatar
Schex
Everyone goes straight for the clutch bearing, I would look closely at the clutch hub bearing's fit in the basket.
To check where the slack is, don't loosen the clutch hub nut, instead, like farm shop said, remove the steels and fibers, then you can feel if the hub is loose on the shaft, or if the slack is between the hub and basket, or both.
Old Mar 20, 2023 | 02:59 PM
86glider's Avatar
86glider
Had it checked at my Indy, he said alls good Surprised he didn’t sell me anything.😂Time to start wrenching.
Thanks guys for your input
blackbear
EVO
Jun 28, 2013 11:07 PM
RidemyEVO
Apr 5, 2013 04:43 PM
JustDave71
Aug 20, 2010 08:17 PM
BAMA_103RK
Oct 22, 2007 09:43 AM
motoxno53
Sep 25, 2007 11:54 AM
