Going back to ECM stock?
Old May 11, 2023 | 09:09 AM
SpringerSoftail2020's Avatar
SpringerSoftail2020
Originally Posted by Spanners39
Change the plugs before doing anything drastic, fouled plugs can pretend to be an ign fault....cleaning them doesn't work.
This is good idea. Gonna do it.
Old May 11, 2023 | 09:54 AM
Max Headflow's Avatar
Max Headflow
Plugs are a good idea.
I had in interesting issue when I first got my evo bobber running.. It has a Spyke single fire coil that is slightly larger/different shape than the standard softail coil. The coil cover was aftermarket and the slot was a little tight where the coil wires came out. The edge of the cover cut into the rubber boot one the plug wire a little. I suspect this may have happened after I'd washed the bike but it sat all day at work, When I went to ride home the bike had a low speed miss. I pulled the cover and install a different one with more clearance and the problem went away.
Old May 11, 2023 | 03:31 PM
SpringerSoftail2020
Took it out for 50 miles yesterday. Still a little stutter, hesitation, but far less. I rolled back the advance curve to 3--so between that (it was on 5, and I am not sure that would do anything in this situation), and tweaking the mixture, things are better--at least in THAT ride. Have some Accel plugs on the way.
Old May 18, 2023 | 03:12 PM
Dehammer's Avatar
Dehammer
That Crane is a notorious POS which I learned of the hard way long ago. I believe it was designed to be good enough for the showbike billet barges of the day. I would begin by shitcanning it before it leaves you stranded. Due to my experience I couldn't trust the SS ones either.
I also agree with the idea that the cone is too hot for electronic longevity. The temp difference and vibration of being in the cone next to exhaust vs under a side panel is astounding. I am amazed they can get electronics to work in the cone at all.
For what it's worth that would be my starting point in getting things right.
Badbastard
Oct 21, 2021 08:51 PM
vtwinbiker
Aug 1, 2021 07:42 PM
toryhardin92
Jun 23, 2020 04:32 PM
Rustyg500
Nov 13, 2016 07:22 PM
roadog69
Apr 10, 2011 06:00 PM
