Starter removal?
Old May 19, 2023 | 06:31 AM
zimm's Avatar
zimm
Default Starter removal?
Yesterday I dropped a battery box bolt and it landed in the abyss under the starter. I pulled the two bolts and unhooked the wires to remove it. The starter would only pull out about an inch and snap back in place. I'm assuming the starter gear is still engaged and wouldn't release. Is there a trick to getting it to come out? Luckily I was able to move up enough to get the fallen bolt recovered. But now I'm curious why the starter seemed stuck in there.
Old May 19, 2023 | 08:13 AM
daven9113's Avatar
daven9113
In order to remove your starter, you will need to open up your outer primary to get to the starter jackshaft assembly. You have to take out the bolt (circled), because that is screwed into your starter "shaft?" See pictures.
Old May 19, 2023 | 11:01 AM
zimm's Avatar
zimm
That would explain why it didn't pull free. Glad I didn't yank on it! Thanks.
Old May 21, 2023 | 09:52 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Get yourself a manual - it will help in instances like this.
Old May 22, 2023 | 04:48 PM
carlgrover's Avatar
carlgrover
Get a lottery ticket too. With that kind of luck you could probably fund your retirement.
carl
Old May 22, 2023 | 09:57 PM
0maha's Avatar
0maha
Little magnets on the end if gooseneck holders are some handy chit.
Old Jun 27, 2023 | 05:44 AM
Riffraff123's Avatar
Riffraff123
That washer with the rubber insert on the end of jackshaft is a one time use item. Will leak if you reuse it. Ask me how I know.
Old Jun 27, 2023 | 02:38 PM
Dano523's Avatar
Dano523
Yes, no, maybe, and if you just clean the parts, and uses a smears of Black RTV on the washer rubber section inside and out as its about seated in place to the bolt head, will seal up fine on the bolt shaft again.
Old Jun 27, 2023 | 06:35 PM
Ghetto blaster's Avatar
Ghetto blaster
If you yank on it to much you'll go blind!
Yupitschief
Feb 17, 2022 05:46 PM
ArtR
Jun 21, 2014 08:42 AM
mostSilly
EVO
11
Aug 1, 2010 12:46 AM
frantheman39
EVO
Aug 16, 2009 07:09 AM
springer96
Jun 1, 2009 05:26 PM
