Evo starting issue
Old Jun 18, 2023 | 10:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by hamah
circuit breaker is open and one side is grounded?
There is no ground on a circuit breaker on a Harley.
The ground is at each electrical component.
OP:
No reason to test that ancient circuit breaker, toss it.
Old Jun 18, 2023 | 12:51 PM
hamah's Avatar
hamah
OP:
Of course, that's basic knowledge. But the question from Jackie Paper was why is it you see 12V across the posts if the circuit breaker is bad. I was speculating because I don't know. I didn't even know you'd test for a bad breaker that way on a Harley. I just replace them when they act up. So what's the answer?
Old Jun 18, 2023 | 12:57 PM
FLHRinFL's Avatar
FLHRinFL
See my original post, #10.
Old Jun 18, 2023 | 01:04 PM
hamah's Avatar
hamah
ahh... I misread that and missed the switch being on. My bad. Still, I've never tested for that and, as with a suspect fuse, I just replace
Old Jun 18, 2023 | 01:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
If the meter reads system voltage across the posts on the breaker, it means the circuit breaker is open.
Of course, that`s basic knowledge.
The meter reads the voltage differential between the probes on the meter.
Old Jun 18, 2023 | 02:24 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I was being polite as best I could. Back up there, if it failed either of the first two test, it was bad. That third test if it was bad and open, you still would not see voltage.
​​​​​​Dan is correct in the fact if it really is blowing and all is good down stream on what it is driving, then it may be easier as cheap as it is to get another.
But it's real easy to actually test if it was open. Not so much if the problem is down stream. Then you need to amp test what's popping it.
I assume this is a cooling off reset breaker.
I was the head of the property committee of a small church. Lead because I fixed everything and also because I didn't do all the hoops to secure funds.
One of the huge heat pumps was not running. Couple checks showed no power on the 100 AMP breaker. I put my analog AC load meter on it . Reset it and it just would not stay in. Everything was off not calling for cool. Problem was my meter was to slow to catch the the load.
That huge breaker was pretty expensive. I ate that one. The compressor was burnt up and one leg of the 120 was ground.
Old Jun 18, 2023 | 02:33 PM
RANGER73's Avatar
RANGER73
Also, the red wire should be by itself. The Voltage regulator wire should be on the battery side. Those circuit breakers are also auto reset. If its not resetting, it’s bad.
Old Jun 18, 2023 | 05:20 PM
RANGER73's Avatar
RANGER73
delete, double post
Greekbuckeye
Jun 14, 2023 07:20 PM
Rains2much
Electrical/Lighting/Alarm
20
Dec 30, 2022 09:39 PM
traildog
EVO
34
Nov 6, 2017 06:49 PM
Steve12
May 21, 2017 02:18 PM
SiggerTX
Jun 19, 2016 03:13 PM
