Oil issue
Old Jun 28, 2023 | 09:00 AM
Jonathan p's Avatar
Jonathan p
3rd Gear
Originally Posted by ohio hd
the check valve is in the oil pump, top side under a large flat blade screw cover. The lower of the two screw covers.
I said, lap, not tap. Some may do that, but i don't. It may not sump oil again unless it sits a long time.
I'd suggest investing in a service manual that covers the evo motor.
lap?
Old Jun 28, 2023 | 09:01 AM
Jonathan p's Avatar
Jonathan p
3rd Gear
Originally Posted by Ohio HD
The check valve is in the oil pump, top side under a large flat blade screw cover. The lower of the two screw covers.
I said, LAP, not TAP. Some may do that, but I don't. It may not sump oil again unless it sits a long time.
I'd suggest investing in a service manual that covers the Evo motor.
Originally Posted by t150vej
Need photos otherwise you're only gonna get (good) suggestions on things to check that may, or may not apply. Example: check valve leakage is irrelevant if it has an oil pan rather than a tank that's above the pump level.
Without knowing some particulars, suggestions and ideas will confuse you and anyone else trying to help.
Old Jun 28, 2023 | 09:22 AM
t150vej's Avatar
t150vej
Sorry, and apologies to OhioHD. I had Road King on my brain (duh) but the photos do help. Good guess on the 90's Evo engine.
You don't have a check valve issue from what I'm reading. You have a feed / pressure problem. Could be the feed gears/drive key or could be the inner drive gear/pinion/key/shaft inside the cam chest.
Here's the sender yellow arrow. With the switch on and that wire grounded the oil light should be on. Wire off, no light.
With the engine running, wire disconnected, there should be no contact from that connection point to ground using an ohm meter.
If that checks out and the light is staying on or flickering when running, you'll need to start by draining the tank and remove the oil pump cover at the red arrow.
Old Jun 28, 2023 | 10:19 AM
t150vej's Avatar
t150vej
I'm mobile now can't do much via phone. Long shot but all considered, search online for proper oil line routing and verify they are correct. Worth a try before taking stuff apart.
Old Jun 28, 2023 | 10:29 AM
Jonathan p's Avatar
Jonathan p
3rd Gear
Ok thanks I'm gonna hunt down a manual and I'll keep updated .
Old Jun 28, 2023 | 02:02 PM
Ohio HD's Avatar
Ohio HD
Originally Posted by Jonathan p
lap?
You make a tool from an old pushrod with a 5/16 end and use it to lap the old by-pass seat with compound so that ball bearing seats and stops fluid bypass. Of course the pump has to come off to do it the right way.
Shovels and Evo's are notorious for the oil bypassing the check ball when they sit for a long time.
Old Jun 29, 2023 | 04:19 AM
t150vej's Avatar
t150vej
You need a manual for the engine (year) otherwise it will not help on this. Scroll down on this page a bit and using the engine VIN, find the year of that engine before searching for a Factory Service Manual. https://www.lowbrowcustoms.com/blogs...-decoder-chart
The oil pump bolt pattern changed ever so slightly in '92, if it comes to that is why you need the year of the engine. Everything else is basically the same.
Oil line routing was a long shot but do need to verify the feed hose isn't restricted. Thing is, the return and tank vent connections are (supposed to be) well above the oil level even if it's over filled.
Here's a link to a long thread you can glance thru of a forum member with a similar issue, but with a stock bike. https://www.hdforums.com/forum/evo/1...ot-enough.html Scroll on down to posts in the 50's and you'll get closer to what you may be looking at on yours.
Old Jun 29, 2023 | 08:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Did I miss the part where the OP put a direct reading gauge on the pump to determine if it was making pressure?
Old Jun 29, 2023 | 09:35 PM
Max Headflow's Avatar
Max Headflow
I doubt it's the anti sump check ball. I'd be more suspicious of that fancy cover on the pressure relief spring.. As Dan says add an oil pressure gauge.. Figure out what you got.
Old Jul 1, 2023 | 08:04 PM
Buddy7394's Avatar
Buddy7394
Frame looks to be aftermarket, so the rest, who knows ?
sportsterchris
Apr 11, 2023 09:42 AM
PacioM
May 26, 2020 07:20 PM
As-21
EVO
15
Apr 3, 2019 05:58 PM
drd21968
Custom Models
Sep 4, 2018 05:44 AM
lebert
May 29, 2010 10:17 PM
