Primary plug - metal shavings
Old Aug 10, 2023 | 09:26 AM
Uncle G.'s Avatar
Uncle G.
It's most likely wear between the chain and sprockets. I'd expect that on a new bike, but it seems a bit much for a well run-in machine. How long since the primary oil was last changed?
Old Aug 10, 2023 | 01:56 PM
GOGOBECK's Avatar
GOGOBECK
Originally Posted by carlgrover
Those shavings look pretty excessive to me. My plug has a sort of gray paste on it when I change the primary oil.
carl
what he said ^
Old Aug 10, 2023 | 09:08 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Originally Posted by uncle g.
it's most likely wear between the chain and sprockets. I'd expect that on a new bike, but it seems a bit much for a well run-in machine. How long since the primary oil was last changed?
6/26/23...
Old Aug 12, 2023 | 09:35 PM
GREENOHAWK69
Opened up the primary and noticed additional rubbing inside the primary cover that I will have to grind down further - see the top part of the photos with the light.
Also noticed 1 ring gear is in half and next to it is another that is about 75%. Do I need to replace the ring gear again? This would be about the 3rd or 4th one now. Not looking forward to it if I have to as they're not inexpensive.
Pinion gear looked a little beat and will replace that again ~ 3rd or 4th time for this.
These items appear to make up the extra "stuff" on the primary plug.
Attached Thumbnails Primary plug - metal shavings-20230812_211201.jpg   Primary plug - metal shavings-20230812_210748.jpg   Primary plug - metal shavings-20230812_210751.jpg
Old Aug 13, 2023 | 07:28 AM
Dano523's Avatar
Dano523
Would guess either clutch basket bearing is bad, .cocked in basket socket for it, or clutch hub has some inner spines cracked of on the inner end of shaft, that is causing the clutch basket to not run concentric with the trans shaft. Hence either hub not mounting tram with trans shaft, or bearing problems to cause basket to not run tram with inner shaft.
So on that note, pull the primary chain, get the clutch out of the basket, check the parts, put the clutch hub and basket back on the shaft with the nut just hand tight and spin the bracket on the inner hub to see if outer basket has outer basket lip in and out wobble as it spinning on stationary clutch hub. Next with trans in netrual, spin inner hub with indicator on it, to see if it running true next. If now, no, then pulls hub and basket,and put indiecator on shaft to see if it running true, or if it bent.
As for basket with bearing/SHELL & SPROCKET W/RING GEAR (hd 37707-94), may just need to replace it, since the starter ring gear teeth are toasted on it.
The after market units already come with bearing, so just a mater of back up the inner bearing race as you press the center hub back into it.
But will note before you go to press the inner hub back into the basket bearing, check to make sure that C clip 8, is tight to outer bearing race 9 to start with. Any gap between the two, really want to pull the C clip and get a shim in place to keep these two tight. With them not bring tight (like need to use punch to get the C clip to seat into it groove tight), can allow the bearing to oblong the socket for it, bearing **** in the socket from primary chain tension, and cause the basket wobble again as pointed out above on the inner hub.
As for clip 7, same same as well,since it holding the inner hub to inner race of bearing so it does not walk in and out, and none of these are really that tight of interference press fits to start with.
Old Aug 13, 2023 | 08:32 PM
GREENOHAWK69
Found the issue, the inner primary had a piece broken off by the main shaft - see attached picture. That is where the marks on the inner primary came from as this piece was stuck behind the clutch.
1) Is this even repairable?
2) I have a second inner primary, but it would have to be drilled out for the mid control shifter shaft.
Old Aug 13, 2023 | 08:34 PM
pgreer's Avatar
pgreer
No, you will need to replace the inner primary at the very least.
Paul
Old Aug 13, 2023 | 08:39 PM
GREENOHAWK69
Edited - added pic of bearing on mainshaft.
3) Did this walk out or am I seeing things?
Old Aug 13, 2023 | 08:49 PM
pgreer's Avatar
pgreer
Looks like it did walk out, but you need to take things apart to see what parts are damaged. I suspect the bearing seized, but until you take it apart and inspect everything, you won't know what else may be damaged.
Paul
Old Aug 14, 2023 | 12:07 AM
Dano523's Avatar
Dano523
bearing installs from the back side of the case.
So need to figure why the bottom of channel socket side was cracked, and allow the bearing to come out that side.
Either bearing seized, primary chain was too tight, trans shaft bearing gone, or something else like high torque and not running a comp.
Hence note that the bearing channel broke to the comp side of the channel, so almost screaming that primary chain was too tight.
Are you running an automatic primary chain tensioner (instead of the manual tensioner), that may have cause the chain to become too tight in the first place?
