Primary plug - metal shavings
Old Jul 29, 2023 | 07:56 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Default Primary plug - metal shavings
Draining my primary (97 WG) on my way to replacing the quad seal that I believe is leaking.
I noted these shavings on the primary plug - what issue(s) am I looking at here?
Old Jul 29, 2023 | 08:03 PM
pgreer's Avatar
pgreer
Probably nothing other than normal wear. It looks like it's just the fuzzy type which could be wear from the compensator. Can you rub it between your fingers like it's dust?
That said, I'd check the inner primary and clutch hub bearings while things are apart. Also check the compensator ramps for excessive wear, but the comp in the EVO motors are fairly bullet proof.
Paul
Old Jul 30, 2023 | 07:50 AM
Dano523's Avatar
Dano523
What bike, since it could be normal, or if you have a spring plate in the clutch (AK grenade plate), could be the spring plate has starting to come apart, and the shavings you are seeing is from the steel clutch basket being groove.
So on that note,would pull the clutch apart to check its parts. If you do have a spring plate in play, and any of the brass rivets are busted, then replace the spring plate.
Old Jul 30, 2023 | 07:04 PM
GREENOHAWK69
97 WG and this was replaced ~ 5 years ago due to what happened in your picture.
Old Aug 2, 2023 | 11:13 AM
GREENOHAWK69
Paul
Yes, very soft. I'll check the compensator when it gets pulled apart this weekend.
Old Aug 2, 2023 | 04:04 PM
carlgrover's Avatar
carlgrover
Those shavings look pretty excessive to me. My plug has a sort of gray paste on it when I change the primary oil.
carl
Old Aug 2, 2023 | 04:14 PM
WP50's Avatar
WP50
That is a bit more than I would like to see.
However if there are no chunks of metal in it just the little fibers ____ How long has it been since a service was done.
If I saw that much a second time I.d be cking somethings out
Good Luck
WP
Old Aug 2, 2023 | 04:41 PM
Yankee Dog's Avatar
Yankee Dog
Just need to closely inspect everything you are removing for the quad seal change out. Curious why you think your quad seal is leaking vs the other seals in the trans?
Old Aug 2, 2023 | 05:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you are going in that deep, I suggest that you replace all the usual suspects:
Main drive gear seal. 12035B
Quad seal. 11165
Sprocket spacer. 33344-94
Big oil seal. 12067B
Shifter shaft seal. 12045
Inner primary bearing inner race. 34091-85A
Inner primary cover oil seal. 12052A
Starter jackshaft oil seal. 12066A
Old Aug 2, 2023 | 06:29 PM
GREENOHAWK69
Quad seal. 11165
Thanks for then info. Multiple items on order.
Guessing based on location after I cleaned up underneath the oil pan and replaced a clamp on an oil line and my breather lines. Bike was up on jack and didn't leak like it did unless running or leaning on the jackstand.
Good Luck
WP
Agree. Hopefully I haven't messed up something from my trip. lol. Fluid was changed on 6/26/23.
carl
Agree. Color on mine didn't seem unusual. I do run sythetic Valvoline ATF fluid.
