Read my plugs
Old Oct 7, 2023 | 05:50 PM
jonnycando's Avatar
jonnycando
Originally Posted by Rounders
I usually turn the idle up on the carb, Don't really see a reason why not to.
There's a thought, but my FXRS is a tad lean, and very cantankerous starting...so I use full choke til it smooths out at 1800...then back it off to 1500 or so, while I feel for heat developing under the rear head on the right side...by then the engine will idle with a bit of throttle blipping. I have the idle speed set so when throughly warm it hits around 1000 to 1100rpm. I reckon everybody has a method that works for their bike and how it's tuned. Ride it like you stole it and the plugs should stay clean.
Old Oct 7, 2023 | 06:05 PM
Rounders's Avatar
Rounders
That seems like a like bit much to start it. But I am not evo guy. Got lots of carbed vehicles I question jetting, throttle cable tightness. Do you have an actual tach on it, and it still takes this? I also get we devlop these routines, especially for older machines
Old Oct 7, 2023 | 06:09 PM
jonnycando's Avatar
jonnycando
Well I dunno...I could put a fatter slow jet in, but when she's warm she's sweet and gets 50mpg...so....and yes I use the tach....FXRS's do have one. If you have no tach, you might only be guessing what your warm up speed might be. And it might be higher than you think. My newfangled Mazda car in cool weather will start up at 2000rpm and stay there a good 30 seconds.
Old Oct 7, 2023 | 08:54 PM
SparkyD's Avatar
SparkyD
If I adjust it to idle when cold then the idle jumps up to 1400+/- once she's warmed up. That's a little too high for me when I'm sitting at a stop light.
Old Oct 8, 2023 | 06:43 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Just set it hot from 950-1000 rpm.. You can only control cold idle with the enricher or throttle lock .
Old Oct 8, 2023 | 08:48 AM
Rounders's Avatar
Rounders
I've never cared if the idle was high. I don't have a tach on FLHR to know. But one of the early things I did was turn up tach so it warmed up better. I doesnt have that cool sounds like it sound trying to pretend I am a shovel sound. 20 years later, I keep thinking I should get portable tach, so I know. Not saying I dont stall once in awhile. Usually on warm starts not choked.
My FI bike was bumped to 1000 or 1100 to.
Old Oct 8, 2023 | 11:19 AM
Rains2much's Avatar
Rains2much
Originally Posted by SparkyD
I have been using the enrichener for worm up until recently. Yesterday I started using the enrichener just the get her started. Then I lock the throttle with the mechanical cruise control at about 1200 rpm. I'm ordering a new set of plugs because these do have quite a few miles on them.
Your idol speech should be somewhere between 900 and 1200. I know a lot of guys like to set it much much lower. But it really should be higher.
Old Mar 4, 2024 | 04:29 PM
FLTRI17's Avatar
FLTRI17
We used to tune bikes headed for Japan to 600 idle rpm to give the idle lope they wanted. We told them about the oil pressure et al negatively affected by low idle rpm but never heard back so I have to believe they had no issues.
Bob
Old Mar 6, 2024 | 08:25 AM
GBHH's Avatar
GBHH
I hope that thumbwheel doesn't prove to be as fragile as that enricher ****.
More smastic.
michaelfab123
Electrical/Lighting/Alarm
Jul 21, 2025 09:46 PM
Fxdeez_
Aug 1, 2022 09:06 AM
Noodelz666
11
Jun 22, 2020 05:41 PM
inswva
Oct 22, 2010 07:20 PM
FACTION95
Exhaust System Topics
Dec 23, 2006 01:49 PM
