speedometer cable doesn't match.
Old Jan 12, 2024 | 07:24 PM
97HS's Avatar
97HS
I hesitate to say yes due to you being overseas
Member Multihdrdr is the wheel fitment guru here, I suggest asking him
Heritage had a cable drive through `95 , that wheel p/n is 43005-86
My worry is that exploded view of the wheel doesn`t show the speedo drive unit.
I admit I do not know
Many thanks for advide .
Ride safe.
Old Jan 12, 2024 | 07:57 PM
97HS's Avatar
97HS
Originally Posted by Racepres
That FLST wheel Should work on any Softail...In Fact...I have one on a 4 speed FLH
Spacers May need to be Made!!
Special Note...Springer Softail Front Wheels are laced Offset..Take Heed and Caution
Thanks and Good news to hear.
I still have FXSTS softail axle shaft .
I hope the speedo gear of evo FLST wheel matches to this ride.
Sorry, don't know what laced offset means , I am studying that.
Eliot.
Old Jan 12, 2024 | 08:01 PM
97HS's Avatar
97HS
Originally Posted by FLHRinFL
As mentioned, all Road Kings are electronic speedometer. 1995 was the last year for the mechanical speedometer on the Softail models.
Oh I see,.
I must select softail wheel which came before 1995.
Thank you sir.
Old Jan 12, 2024 | 09:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by 97HS
Oh I see,.
The wheel part numbers did not change when the electronic speedometers came out, they just eliminated the drive unit and used a spacer (in place of the drive unit) on the left side.
Are you trying to find a 21-inch wheel, or 16-inch wheel?
Is that springer a Harley Davidson part?
The OEM front wheel part number used on FL Softails (laced wheel) is 43005-86, this part was used from 1986-1999.
That is the wheel in my sig picture.
Old Jan 13, 2024 | 03:14 AM
97HS's Avatar
97HS
Thanks.
Exactly, I'm trying to find 16" that uses front speedo drive unit which my 1991 FXSTS has.
From what I've learned here, I narrow down to the following.
1. Softail models that use front speedo drive unit were issued until 1995.
2. I may need new spacer.
3. Now, 43005-86 is the part number of OEM FL softail model.
thank you sir.
Old Jan 13, 2024 | 06:54 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks.
The laced wheel assemblies used on FL Softails from 1986 through 1999 are all the same.
All will work with a mechanical speedometer drive unit.
Old Jan 13, 2024 | 10:18 PM
97HS's Avatar
97HS
I appreciate your help sir.
I googled and Speedo unit and axle kit have variations depending on softail models.
I 'm keeping my stock FXSTS speedo unit and axle kit.
I must change all of them too? or Can I use stock axle with only spacers changed?
Thanks anyway.
Eliot
Old Jan 14, 2024 | 02:22 AM
97HS's Avatar
97HS
While searching for proper parts, I've found new parts.
Is there anyone who know or experience this part?
https://www.mid-usa.com/48613-vfacto...it-for-softail
SamFontaine
General Topics/Tech Tips
Jun 9, 2015 07:11 AM
cjshovel
Shovelhead
Aug 28, 2013 02:06 AM
highwayman
Mar 5, 2013 03:04 AM
Oldtigercub
Mar 20, 2011 07:32 PM
jammer1
EVO
Feb 1, 2008 03:19 PM
