Bought the bike, replaced the plugs, ran a little over 3000 miles and reached the 15k service so I pulled them to find this. Is this normal?
Am I running rich? For sure smells like it. Where should I begin?
I replaced them today and road around for an hour. Its always ran great and never had any major problems, just basic maintenance and slow warm up time, youd expect from a 30 year old bike
But i would say it runs pretty hot, Ive been reading about switching the coil/ignition module to single fire instead of dual, would that help clean these plugs up any?
Thanks for any help
IF ( thats an important if..) you pulled them correctly, theyre definitely reflecting a somewhat rich condition.
Easiest ( read: least costly) mod to try is another set of plugs that are a bit hotter.
Whatever you do, dont make the mistake of lugging the bike around, through the neighborhood for example, then pulling the plugs to read them.
I agree with John idle looks rich on those plugs.. Everything else looks pretty good though... However I wouldn't be running champions try NGK BPR5ES... And set to .038"
