Ignition Woes...
Well really sucks is the other bikes apart too I'm without a ride right now... ****ing hey..
The regulator hot wire is on the load side of and runs through the main circuit breaker back to the battery, what if the breaker has high resistance under load or intermittent circuit trip? or a bad battery? but I think you tried another already.
If the bike was running you could temporarily put the regulator wire on the battery side of the breaker and take a ride and monitor voltage, I take it you could see the spikes? to bad you couldn't data log voltage to know for sure if that's what's going on.
I don't see how the AC side, stator or rotor, could cause overcharging, maybe somehow it could?, I don't know.
What you doing to the Dyna?
I quick little story, on my 17' RG the tpms I have has a digital voltmeter, I'd press the voltage button and it would be at 15.1, check it again ,15.3, check it again, 14.3, it would steady out after a while. I checked every connection I could, the only thing I found was the spades on the maxi fuse looked funky, the maxi fuse connections are exposed to the elements, I scraped them clean, worked the fuse in and out of the holder a few times, took care of the issue.
Just a FYI note, the '24 bikes have a different, weatherproof main fuse design, hmmm.
I’m sure you did but I have to ask.
I'm pretty confident you nailed it.. Even though I did replace the stator I also went to AutoZone and purchased a new 30a breaker.. The thing is though if the breaker did have an intermittent trip I would have at least had an interruption in the ignition as well because the feed for the ignition switch comes off the same post on the breaker..I don't know, well see what happens tomorrow.. Rain kept me from going on a test drive.. But the little it did run I did not get a single spike.. To be on the safe side tomorrow I will add another 30a breaker separat the ignition switch from the charging system.. couldn't hurt..
A friend of mine had a bunch of OEM ignition modules and dual fire coils.. So I installed the module from a 95 883 Sportster.. Not sure what the RPM limiter is but I'm pretty sure they have an aggressive ignition curve.. Throttle response was amazing and I also had to increase the idle mixture screw.. Tomorrows rest ride will tell..
I would also like to add that I put a brand new battery in so I think I covered everything and it's still there I don't get it... Last thing I want to do is blow out another ignition module..
Can you figure out when the voltage jumps?
