.030" cam end play from factory?
Old Jul 22, 2024 | 02:31 PM
drakejam's Avatar
drakejam
6th Gear
Default .030" cam end play from factory?
This is the cam end play I am measuring in my 1998 ultra classic FLHTCUI EVO with round stock thrust washer (25550-57a) and no shim. All I have done is install a new cam bearing and cam/gear cover. The smallest shim I have is .050" which is too wide for me to get the ideal cam end play. However, the .030" cam end play I am getting is in spec per the book. I think the max spec is something like .050" max end play.
You think Harley QC let this .030" end play go?
It looks like I need to find thicker cam cover gaskets to fix this. Something like a .070" thick gasket
MY current HD gasket measures .035 and I have taken the crush into account.
What would you do?
Old Jul 22, 2024 | 02:54 PM
johnjzjz's Avatar
johnjzjz
I have seen that many times - what we did you dont have the tooling to do - its called a surface grinder - we take another inner plate and spilt the difference grind both to what ever so we have .012 in the end play with the oil gasket that is thinner then the new one then install the new gasket
if you just grind one its too thin and its not a good spacer its prone to fail by getting hot and reducing its size shedding metal
Old Jul 22, 2024 | 05:16 PM
t150vej's Avatar
t150vej
After '90 or thereabouts, the cams were longer and the factory end play called for .050 - .010.
If you buy an after market cam you have to start with at least .050 spacer and usually need more. After market sells cam shims in various thickness. If you're using the original cam and have .035 end play, run it.
Old Jul 22, 2024 | 05:43 PM
Spanners39's Avatar
Spanners39
My experience (and the advice from my Indy) is that end play really isn't a biggie, more than 3 thou and less than 50 thou is about right, you can't feel or hear the difference.
Old Jul 22, 2024 | 08:44 PM
drakejam's Avatar
drakejam
6th Gear
Thank you much for the info. It's guys like you that really makes these forums valuable.
cowboy 51
EVO
18
Nov 27, 2014 02:58 PM
Uncle G.
EVO
Apr 15, 2014 07:11 PM
dano13208
Engine Mechanical Topics
Mar 17, 2014 05:42 PM
zimm
EVO
14
Nov 17, 2013 04:00 PM
StuxnetKiller
EVO
Jun 25, 2013 10:13 PM
