ATF in primary
Old Jul 28, 2024 | 09:02 PM
Spanners39's Avatar
Spanners39
Originally Posted by Dr.Hess
I run ATF in my big twins.
I run ATF in my Shovel...not very much as it is a dry clutch, but that is what I run.
Old Jul 28, 2024 | 09:20 PM
Y2K's Avatar
Y2K
Wink
Just to be clear some early Evos also had the dry clutch and were fitted from the factory with a chain oiler and oil return.
I'm assuming Spanners did something like this with the Shovel mentioned as the dry clutch primary didn't have any oil in the case from the factory.
I had an early '84 Evo with this system but soon plugged off the chain oiler and return lines and swapped in Barnett wet or dry clutch plates then ran ATF.
The old system had clutch debris going back to the motor oil,not a good system even though it went to the oil filter first.
Old Jul 28, 2024 | 11:35 PM
Spanners39's Avatar
Spanners39
I knew that....it has not had the chain oiler in a very long time....useless idea it was..."hey, let's pour engine oil over a chain that spits swarf and a clutch that spits asbestos and send it back into the motor..."
Old Jul 29, 2024 | 07:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I tried ATF once in my Evo and am not sure if it was a proper lubricant for the clutch plates.. My motor is built and is almost twice the power of stock.. After about 1500 miles on the ATF there was this god awe full smell similar to a burnt up automatic.. Took it out and went back to primary fluid.. In an automatic trans I believe the pump pressure is up around 400 psi so the clutch packs get a lot more fluid than that in our primary's.. I'm sure every one has a different experience with the use of ATF.. This was mine...
Quick note, in that video that was posted in which i didn't watch the hole thing but did that guy put it all back together with the rivets in the spring plate coming apart??? WOW....
Old Jul 29, 2024 | 07:52 AM
Dr.Hess's Avatar
Dr.Hess
Yeah, and to stop it from grenading the rest of the motor, we'll put a fine mesh screen in the oil feed going to the lifters to catch the clutch plate material that misses the "sort of" filter in the oil tank.
Old Jul 29, 2024 | 09:11 PM
Racepres's Avatar
Racepres
^^^ Yet those old Shovels went oodles of miles...Stock... More than Evo lifters go!!!!
If that crap is Not stopped by yer filter...something is Very Wrong...only the return side of the Pump suffers...and it keeps on tickin!!!
Old Jul 29, 2024 | 10:25 PM
Spanners39's Avatar
Spanners39
Trouble is that the tappet screen gets blocked and then oil starvation issues. Best not spray ***** into a perfectly good motor.
Old Jul 30, 2024 | 07:55 AM
Racepres's Avatar
Racepres
Tappet screen is not Fed dirty (return) oil...not on My Bike anyway...Nothing Used, is sent into Motor...Only oil from the Tank is fed.. Again...yer oil filter catches stuff in Return oil, and once in awhile we do douche out our oil tanks...Like the Book says...Right?? Just in case some crap gets thru the Filter!
Old Jul 30, 2024 | 08:05 AM
Dr.Hess's Avatar
Dr.Hess
Yeah.... Having lived through the ShovelDaze, a top end only lasted about 25-30K miles. Then you needed to rebuild it, and do the bottom end about every other top end. How is this "oodles of miles"? So, stock Evo lifters are a 50K scheduled maintenance item, and the motors themselves are good for at least 100K without a new top end.
Old Jul 30, 2024 | 08:35 AM
Racepres's Avatar
Racepres
IDK who rebuilt your Shovel..but, mine last easily as long as an Evo, and the tappets last longer...just don't breathe as well..
But..."My Dogs Better than Your Dog" But, My Evo got a bad Lifter at just over 30K, Tho, Factory Built.
Anyway...point really is...Don't hurt as much as we would Like to Believe to return that Primary Oil thru Filter...But, we all talked ourselves into feeling superior because we Isolated
