evo top end
Old Aug 14, 2024 | 10:36 AM
horslips's Avatar
horslips
Default evo top end
I have to rebuild the top end on my '91 softtail anyone have any experience with Tman products?
Old Aug 14, 2024 | 11:59 AM
98hotrodfatboy's Avatar
98hotrodfatboy
What are you looking for?? Very generic question.. They have good products.
Old Aug 14, 2024 | 03:54 PM
Dano523's Avatar
Dano523
Devil in is the detail, so is idea to just rebuild motor to stock spec again, or are you going to build motor with higher compression to get more power out of the motor.
As for top end, make sure that wrist pins are still tight to connection rod top bushings,and if not,then plan on replacing the bushings as well.
By tight, should still be able to slip into the bushing, but not be able to cant the wrist pins in the channels isntead.
Hence rabbit hole begins on a rebuild, when Jugs cylinders are so worn, that they need to be bored and next size piston installed, verses just cross hatching the cylinders.
Compression wise, can face bottom of jugs when lathing off gasket, to bump stock compression a touch (want piston squish to be .030" with new base gaskets being used), while if you are bumping up to 10-1 or over, than may have to get into compression releases so your not frying starters.
Also, when you have the cam out, want to check crank run out, to determine if you need to go next step, to pull the case apart to address major crank run out problems there and them, including rebuilding the bottom end as well.
Bigwillie
EVO
21
Aug 9, 2024 09:54 PM
86glider
EVO
15
Jun 10, 2022 08:22 AM
Bama91
EVO
28
Sep 6, 2021 07:35 AM
bluharley
EVO
Jul 12, 2014 04:22 PM
JimA
Mar 11, 2012 07:38 PM
