Let the rebuild begin
https://www.hdforums.com/forum/evo/1...appearing.html
Of everything going back together.
TLDR. Motor had excessive oil burn due to many factors explained in old thread. While apart I decided to go a bit crazy.
Bike : 1998 FL Road King 33k miles started life as a E Glide Standard. Then custom converted to a Road King.
Bored 20 over
10:1 Weisco Forged Pistons
Heads reworked by Hammer with beehive springs, competition Valve grind and some massaging.
Hammer Performance Pushrods
S&S Big Race tappets
S&S Breather Gear
Reaper 543 Cam
S&S 2-1-2 Headers
S&S 4 Slash Cut Mufflers
EZ Pull Clutch Kit
oil pump reseal kit
Cometic Gasket Kit
S&S Head studs
Billet Proof Tappet block alignment kit
Things are starting to go back together. Thanks to everyone so far that has helped. Building up an Evo is a first for me but I have grown up building hot rods and currently work building Street rods and Muscle cars doing all out builds to full on rewiring and custom stuff. So I have the tools and knowledge just need some guidance.
I fought shimming the cam due to some errors in data and confusion but now with a .050 shim and the factory thrust washer with a crushed gasket Im at .024 of end play. I could make it tighter but it starts running the cam off the front (outer) part of the pinion.
Breather wont need a shim as its within spec without one.
there has been some discussion about the Cam probably not designed for a heavyweight bike. Originally we discussed the Evo 5005 but its been unavailable to his vendor and I discussed wanting a cam that ran well on the highway and freeway running with power to passs. The reaper 543 was swapped to the list. Granted it has a dip in the low end torque. But its still better than the N Grind that came out. So will see how it works I guess.
ignore the yellow mark on the pinion. That is my mark to see the timing mark. There was no marks on the cam or pinion that I can see.
And yes I had my old cams gear pressed on the new cam.
Cam gear should have two marks (can see the one for breather and second should be behing the shaft up to the right), and can see T mark on breather valve valley, to mate up with cam tooth mark that is visable..
As for no spacer for breather, would see about adding something (even if flush with button), since better to have nylon rubbing on the inside of the nose cone cover, then metal against metal instead.
Ive got to pull the trans cover and oil fill off of it still to remove the original exhaust bracket. And take my oil pump apart to check the gears and reseal it. Then hopefully I can start focusing on dropping jugs back on and sealing up the motor again.
The S&S 2/2 head pipes but I went with the 4 slash cuts over these. Wanted as free of flowing exhaust and not worry about reversion popping anymore. With all the head work I had done I want to maximize flow.
81 Chevy K10 Silverado. His dad bought it new and never intends of selling it. We stripped all the OPEC emissions off it as well.
So dont let your dreams of doing any work in the driveway get away. Lots of us have been there and made it work. Just keep things dry and covered up and sealed the best you can if you live in a wet environment. A bit of WD 40 helps as well.
I have to pull the trans and oil filler covers off to remove the exhaust bracket. So Drain fluids.
still have to pull the oil pump apart as well.
Hopefully tomorrow will be better than last week. Ending up in the ER again.
But in process found more evidence the motor.has definitely been out totally. Couple hoses have worm gear clamp impressions under the OE style clamps.
On that subject anyone have a lead.on a handful of the OE clamps? My local Tacoma Screw used to carry them. No longer.have the smaller ones. HD wants $5
a pop for them.
