No Start
I can teach you very easily how to load test the entire starter and major grounds if you simply have a digital volt meter.
I have a digital volt meter..
Put the negative (-) meter lead on the positive (+) battery post. Not wire or terminal, the post. I usually hold that one and use a clip for the others. Red meter lead on the long post of solenoid and run stater just long enough to get a reading. Write down reading.
Move the red lead to the short post on the solenoid, run starter. Write down reading.
Move red lead to the post on the starter motor. Run starter. Write down reading.
Connect the negative meter lead to somewhere on the engine or transmission. Connect the red meter lead to the negative (-) post of the battery. Run starter. Write down reading.
Long post 4 v
short post .5 v
"Move red lead to the post on the starter motor"
Not sure what to do here. I dont see any post on the starter motor.
After testing the short and long post on the solenoid she started smoking. Appears to be coming from the starter or that area. Smoke was coming up through the oil tank at the front of the battery. I killed the dash and handlebar switch. It started turning over on its own. Bolt on the negative terminal post started glowing. All this in a matter of maybe 5-10 seconds.
Have a friend coming by to take a look sometime next week.
Long post 4 v
short post .5 v
The negative cable (I think) connects to the starter gear housing on backside of the primary. Just a guess, it's what's smoking. Good luck next week.
Was talking to someone else and he suggested I pull the starter and ensure it runs. With the smoke coming from that area I kind of assumed the starter was bad. Pulled and tested and it seems to spin fine. I had to pull the oil tank and exhaust to get it out so I have pretty good access to all wiring. Tested continuity on all the starting system wiring and every thing seems fine. This was done with a power probe. It's hooked up to the battery and has an extra ground. Connect the ground to one end of wire and probe with the other. I get a green light and a beep. First time doing this so not 100% sure that's correct but that's how the instructions explained it. Don't see any damage to wires from cuts, wear, or heat. Starter does smell funny. Also pulled the primary cover to confirm nothing was broken or jammed up.
Still don't why I wasn't getting 12v to the solenoid switch post, exactly where the smoke came from, how and where it was trying to hotwire itself, and why my battery bolt was glowing. I'm thinking I need to hook the battery back up and trace power for 12v from the solenoid, through the switches, and back into the relay? Getting closer and closer to putting it back together and trailering it to a shop
Loose wires will make contact areas very toasty. I even had a terminal on the battery melt away on the shovel once from a loose connection.
I'd also install a push button on the solenoid end for just these special occasions. Got them on both scoots with the 5 speed cases.
Griz
Griz
From Jockey Journey website:
"You can make your own "push-button" for the solenoid you already have. Just take a piece of flat stock bolt it to the terminal with the Battery lead. put a bend in it so it is sitting above the other terminal, put you rubber boot back on and when you push the boot you will be basically jumping the solenoid"
Griz
