Another CV40 question
Old Jul 7, 2025 | 11:13 AM
FinGlide's Avatar
FinGlide
Originally Posted by Spanners39
On Aussie and NZ fuel, 200 main isn't as out there as our American cousins may think.
I ran a 200 on my 1998 Wide Glide, with an EV27 cam.
Hard to believe. I have also EV27 cam and I can not use that big main jet. Way too big yet for european gasoline. You drive most of the time with the the idle adjustment and intermediate jet, only when the full throttle you use the main jet.
Old Jul 8, 2025 | 06:18 PM
Spanners39's Avatar
Spanners39
Bear in mind how hot it gets in Aussie, you gotta keep it from running lean or the pistons melt, main also affects the intermediate settings as the intermediate draws fuel through the main jet.
But the real reason is the Drop Bears, the smell of unburnt fuel keeps them in the trees and off your head...
Old Jul 9, 2025 | 02:43 PM
Muskrat21's Avatar
Muskrat21
G'day Fellas.
The new choke cable is in and working. While I had the carb off I threw in a #50 pilot jet just to see. SSDD (same **** different day). At a low Idle I can screw the mixture screw all the way in or all the way out (6 turns) with bugger all difference. I know 100% all the jets & passages are clear. The only way so far to get response from the screw is to use a #42 and then it's only 1 turn out. With the K&N and V&H it should need bigger. GMF.
Cheers
Old Jul 9, 2025 | 04:48 PM
t150vej's Avatar
t150vej
I wouldn't worry with it. It's all sealed well and the 42 is what it wants - with that cam. Pipes and air filter have nothing to do with the idle.
At the most, if upon riding until up to temperature, it pops on decel, it may need a bit more out on the screw.
Old Jul 9, 2025 | 05:14 PM
Hasher's Avatar
Hasher
Generally I use a 45 pilot and 195 main.
Old Jul 10, 2025 | 02:24 PM
Muskrat21's Avatar
Muskrat21
G'day T150, Hasher.
The pilot jet works through the whole range from closed to wide open throttle. I'll throw the 42 back in but will keep a close eye on higher throttle settings. May need to shim the needle.
I can't test ride yet as I'm trying to sort out the new blinkers not blinking.
Cheers.
jedwardson
Exhaust System Topics
Jun 11, 2013 11:07 AM
Little88jr@yahoo.com
Carburetor Related
Jun 20, 2011 02:31 AM
Jim Kraft
EVO
17
May 21, 2010 03:11 PM
84157
Aug 9, 2009 10:23 AM
big jon
EVO
Jan 12, 2008 12:28 PM
