Cam upgrade Andrew's 23
Old Aug 5, 2025 | 06:46 PM
02fx's Avatar
02fx
Is your carburetor stock. is the air filter dirty/restricted. Start there it's inexpensive and easy. My bike has stock ignition and a cam /big bore runs fine. I'm running a mikuni. But a stock modified CV work great .
Old Aug 5, 2025 | 07:10 PM
Racepres's Avatar
Racepres
Both the motor and exhaust generate heat. They need to balance in such a manner that CHT and EGT are balanced to there own optimum number. Say 300 F for the heads and 600F for the pipes. The pipes are smaller and typically have heat shields where the heads and rest of the motor has more surface area to radiate heat.. Anyway too retarded and fuel burns in the exhaust pipe. Too much advance and more mixture is burned in the motor.. It's temp will increase and motor radiate more heat... CHT goes up.
Bullshit
Retard yer timing...tell me the First Symptom!!!
Remember...the Thread concerns (supposedly) nothing but a Cam Change!!
Old Aug 5, 2025 | 07:48 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Racepres
Bullshit
So you are saying optimum timing does not change with a cam change? I would disagree.
Yeah, the heat goes up... Like I wrote. Overall heat may go down if too far advanced in the first place. If the OP simply marked the timing plate an did not set it, the timing could be anywhere.. The cup notch may be in a different place..
My bobber ran too much timing and the motor would overheat. You could feel it.. It crisped a crank seal. I don't have the dyno runs but with 3 pulls you could see the motor overheating from too much timing. Power dropped off with each pull.
Old Aug 6, 2025 | 07:20 AM
Racepres's Avatar
Racepres
^^^ Whatever...regardless...first suspect when changing a Cam causes any Problem = Timing.
Old Aug 7, 2025 | 04:25 AM
t150vej's Avatar
t150vej
@Toneloco Two things would cause that, as mentioned the timing may be high. Even if you marked the plate to the cover, changing a cam/gear will through it off.
The cam turns backward so turn the timing plate clockwise to advance timing or counter-clockwise to retard timing.
Did you replace the carb to manifold gasket? Air intake will make them run hot too.
Old Aug 7, 2025 | 07:01 AM
Racepres's Avatar
Racepres
Agree...But, Intake leak is Not normally a Result of a Com Only change. Possible certainly.
Personal experience shows me. Retarded timing makes more Heat, than Advanced.. Too much advance, should reveal itself in starter Kick-back, and Pre-ignition.. I guess if Ignored..more heat will result, just before you hole a Piston ...ie, The original symptom was ignored!
Old Aug 8, 2025 | 11:52 AM
Toneloco's Avatar
Toneloco
Originally Posted by Greaser1340
The 23 is a fairly mild cam designed to work with a relatively stock 80" Evo. You can run it with your stock ignition just fine, however, if you want to maximise performance and have your timing / rpm limit adjusted to get the most out of your modifications - an aftermarket ignition would be a nice addition. You can always put it on the shopping list for later.
If you are running noticably hotter after swapping out the cam sounds like you might be running the motor lean. Have you bumped up your jet sizes to account for the new cam?
What do your spark plugs look like?
I did the carb adjusting and plugs where alil dry im thinking if possible the timing would it run if timing wasnt on tdc compresion being on the downstroke just a wild guess
Old Aug 8, 2025 | 02:49 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Default Easy enough to find out
Just jack up the rear and check your timing and then you will have eliminated that question.
Griz
SparkyD
Shovelhead
Jul 25, 2021 07:33 PM
pnwsurveyor
EVO
Sep 18, 2018 06:43 PM
greg6746
EVO
Apr 23, 2018 11:13 AM
dylan4695
Exhaust System Topics
Mar 21, 2009 10:55 PM
