Pulley Question
Old Feb 13, 2026 | 07:20 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by cwhite6
Is there any reason that a 34T pulley off of a 1993 Heritage would not fit my 1998 transmission?
I would recommend not using the earlier transmission sprocket, they were well known to work loose and cause all kinds of expensive headaches.
In mid 1994 the factory came out with an upgraded sprocket and hardware.
The sprocket was thicker in the spline area, also the spacer was made shorter to accommodate the thicker sprocket.
The spacer outside diameter was increased to lessen the chance of the sprocket wobbling on the shaft, and the big oil seal inside diameter increased to accommodate the larger diameter spacer.
Old Feb 13, 2026 | 04:11 PM
cwhite6's Avatar
cwhite6
Thank-you for the advice!
texashillcountry
EVO
33
Feb 28, 2015 11:14 AM
rcroadrider
Jul 22, 2014 05:57 AM
jsbridgew
EVO
34
Jan 30, 2011 02:24 PM
anubisss
Dec 2, 2010 12:33 AM
bsteve
Shovelhead
Oct 24, 2010 02:10 AM
