5-speed Main Shaft Seal
Old Mar 1, 2026 | 04:32 PM
Joe12RK's Avatar
Joe12RK
Originally Posted by t150vej
I recommend you pull the gear set. It only requires 2 more gaskets. That way you can dress the main shaft where the seal has run.
Doubtful there's much of a groove but I've learned over the years, regardless of the machine, always best to always have a clean, smooth surface for a new seal to ride on.
Yes, I am going to pull all the guts out and look them over, except for pressing out the main drive gear. The gasket set will have everything I need.
Old Mar 2, 2026 | 05:47 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I would also replace the spacer, oil seal, and quad seal that are hiding behind the transmission sprocket.
Use new locking bolts for the retaining nut lock plate.
customsoftail200
Jul 23, 2025 09:11 AM
Randy2021
Jul 1, 2024 03:22 AM
WoodsHog
Jul 19, 2014 04:51 PM
kansasroadking
Jul 7, 2008 07:18 PM
ritz
Nov 30, 2007 07:26 AM
