Are there torque values for the handlebar clamps?
By which i mean the 2 large bolts that go trough the top yoke into the risers, as well as the 4 small bolts that clamp the bars to the risers.
I'm replacing the bushings in there hence the question.
I don't see anything in the manual.
I was shocked when I found out the clamp bolts are only supposed to be around 17-18 ft-lbs, I used to crank them down real tight. Now I have mine set at 18 ft Lbs. and they havent budged.
