weird turn signal issue
Old Feb 24, 2008 | 05:35 PM
ssls6's Avatar
ssls6
Default weird turn signal issue
My indicator light for the left hand blinker wasn't working this morning. The right side worked fine and the left side was flashing. About half way through the left side started flashing again. The bike is a 98 evo RoadKing. Anyone ever seen this before?
Thanks,
Richard
Old Feb 24, 2008 | 06:39 PM
badherb's Avatar
badherb
Default RE: weird turn signal issue
nope but you got to check your light bulb receptical for rust. make sure your wires under your fender are not worn through and grounding out. check to make sure all your lights are not burned out. In general if you have and indicator problem it will be in one of these areas.
Old Feb 25, 2008 | 05:08 PM
Beemervet's Avatar
Beemervet
Check for a bad ground.
Old Feb 26, 2008 | 07:16 AM
dert's Avatar
dert
bulb socket is the ground.Sometimes they will become loose from vibration.Its a one wire setup.Check the socktet for tightness and if loose or slips around on the base,try putting some silicone on the outside of the socket once you tighten it.I chased a similar problem for months.
Old Feb 26, 2008 | 08:04 AM
ssls6's Avatar
ssls6
Indicator bulb in the dash? That would make sense.
Old Feb 26, 2008 | 08:15 AM
fmbeach's Avatar
fmbeach
Ssl,
Getting slighty confused.
Did the LH signal work but not the dash indicator or were both out?
Are your LH running lights working and not the LH turn signal?
If you have running lights it is probably a bulb heading South or a corroded socket - dual filiment bulb. If a dash lamp is intermitentit's probably socket corrosion as well.
Good suggestions so far .... please clarify a bit.
Glenn
Old Feb 26, 2008 | 08:26 AM
ssls6's Avatar
ssls6
Both turn signals work and parking lights work (as seen from the front or rear). The left hand side indicator was not working (dash light in tank console). It started working again by the end of my ride. I had just finished a rockerbox gasket repair so my tank console had been removed and layed back.
Now that I know each dash indicator is a seperate bulb, I have a pretty good idea what happened. Thanks for all the help.
Old Feb 26, 2008 | 09:09 PM
mgray's Avatar
mgray
Stage IV
Does your speedo work ok? The magnetic sensor in the top of the trans may need to be cleaned. This can mess up your self cancelling sigs also. Marty
Old Feb 27, 2008 | 10:45 AM
im's Avatar
im
each dash indicator bulb is seperate...most times they are not burned-out..just need to wiggle and reset in place..
remove the screw and bolt that hold console to dash..carefull / cover tank to avoid scratches and flip over..not to difficult to remove plug socket and bulb..be really carefull and cover tank with large towel..if you need bulb the dealer has it and so do the auto parts stores...good time to change-out that plastic little indicator window the one with the turn signal arrows , neutral, hi-beam..that piece gets ugly over time.
Old Feb 27, 2008 | 08:45 PM
89 FXRS's Avatar
89 FXRS
I had the same problem at one time and could not for the life of me figure it out. After checking the whole system I was baffled.
For some strange reason I replaced the flasher and it started to work. I know that it makes no sence. Just thought I would let you know.
JorjorAZ
Harley-Davidson Street
Jan 23, 2017 05:26 PM
sputnicbmx88
Aug 9, 2013 07:41 PM
broncobob
Jul 5, 2013 11:10 AM
vdubbug_2
Sep 13, 2012 07:01 AM
Black Train
Feb 20, 2011 12:38 AM
