Leaky evo?
Old Mar 19, 2008 | 10:11 AM
92Fatty's Avatar
92Fatty
Default Leaky evo?
I was just curious, i've owned it since 98 and it never leaked. That is until last year with rocker gaskets and inner primary. So i changed inner primary oring, it was dry around the other 2 seals, and last weekend changed all rocker box gaskets. I still have one little quarter size leak grrrrrrrrrrr. I'm wondering if this is just due to more blowby and it being a bottom breather having 40k miles. How does yours stack up? In an oil change cycle i usually drop about a strong pint @ 2000 miles then change at 3000. I think most is going out the breather/air cleaner due to no smoke out the back and clean plugs. ok be honest how does your evo cycle with regards to oil usage in the change cycle. Thanks Kent
Old Mar 19, 2008 | 10:48 AM
Mr1986FLST's Avatar
Mr1986FLST
Default RE: Leaky evo?
I use about a pint also, every 1.5-2k miles...I have 50k on a rebuild, dino oil changed every 2.5k.
Old Mar 19, 2008 | 01:05 PM
sqdealgeorge's Avatar
sqdealgeorge
A pint or a pint and a half At 2000 miles Is normal I've got 60,000 and use the same
Old Mar 19, 2008 | 03:32 PM
92Fatty's Avatar
92Fatty
Thanks for info. I also useDino oil.
Old Mar 22, 2008 | 08:07 PM
Hackd's Avatar
Hackd
ORIGINAL: 92Fatty
...I still have one little quarter size leak grrrrrrrrrrr.
Where is this leaking?
Old Mar 23, 2008 | 02:56 AM
pepesworld's Avatar
pepesworld
Mine a 98 also, never leaks a drop. At sustained high speeds on the road I think itburns a little more, seems like a quart after a week or so.
Old Mar 23, 2008 | 11:51 PM
notlost_nc's Avatar
notlost_nc
Mine doesn't leak oil, but it likes to burn it
Old Mar 25, 2008 | 02:58 PM
grbrown's Avatar
grbrown
I have recently cured a leak out of the alternator plug, otherwise it has stayed 'oil tight', by which I mean it hasn't leaked running oil, just a bit of misting in a few places, in 40-odd thousand miles.
Our toughesttrip was when we shipped our bike to the USA for Harley's Centenary and toured fully laden for 3,500 miles, the longest I have ever done. It used a quart every thousand miles, most of that riding in the 90s, which is pretty hot by our standards. I don't reckon I could have asked any more of it!
MJHJEA
EVO
23
May 8, 2018 06:49 AM
NicholasJ234
Oct 2, 2012 05:54 AM
j1mmy
Shovelhead
Jun 20, 2011 10:49 PM
98 roadglide
EVO
33
May 23, 2009 07:01 AM
winpitt
Exhaust System Topics
Oct 3, 2006 01:49 PM
